- 09-12-2012, 01:43 PM
Thread Author #1
- 09-12-2012, 01:52 PM #2
Re: Stuck in boot sequence
Did you try a soft rest? Hold power and volume down for about 15 seconds. The you will see a quick flash on the screen and it should boot up.
Sent from my RAZR MAXXIMUS
- 09-12-2012, 03:16 PM
Thread Author #3
I tried that's volume up and down both by the way volume down takes a screen shot. After a few attempts that did it though. But only after I called Verizon. I had a burnt out pixel anyway so I got a replacement coming lol. Phone is still trucking though
Sent from my GT-P7510 using Tapatalk 2 - 09-12-2012, 03:20 PM #4
No.. Soft reset is power and volume down. Trust me. I does both.
- 09-12-2012, 03:29 PM #5
Yeah, it's kind of silly that the button combination for soft reset is exactly the same as that for screenshot--it just depends on how long you hold the buttons down for. Holding them down for about 2 seconds gives you a screenshot; holding them down for 10-15 seconds soft resets.
I think another difference is that to take a screenshot, you really have to press the power and volume down buttons at the exact same time, whereas to soft reset, it doesn't have to be at the exact same time. - 09-12-2012, 03:33 PM #6
The best way I have found to do a reset without taking a screen shot is to turn the screen off, then hit power and volume down, and it will turn the screen on and reset but without taking a pic
[HELP] UNBELIEVABLE...Stuck in Boot Loader mode.
By the spcs guy#ac in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 10Last Post: 10-18-2010, 04:04 PM -
HELP!! i am stuck in boot mode!!!
By daryl6784 in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 7Last Post: 10-02-2010, 10:33 AM -
HELP!! stuck in boot mode
By daryl6784 in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 7Last Post: 10-02-2010, 07:51 AM -
HELP!! Lost SD card and all nandroid backups, now stuck in boot loop
By handbra#ac in forum Incredible Rooting, ROMs, and HacksReplies: 20Last Post: 09-22-2010, 09:24 AM -
Stuck in boot, and cant get into recovery
By jwortiz in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 11Last Post: 07-31-2010, 08:12 PM
Reply
