Results 1 to 15 of 15
    Default Need Help ASAP Please!
    Razr Maxx is stuck on "Android System recovery (3e)" I can' get out of it. I was rooted trying to restore back to the stock rom when it said error and send me back to the stock recovery. I can't get out of it. Can't install old stock rom. please help. thanks
  2. #2
    Default Re: Need Help ASAP Please!
    Quote Originally Posted by BigJav209 View Post
    Just hit it with a hammer until the screen goes black. That should work... :P
    Sent from my DROID RAZR using Android Central Forums
    Razr Maxx- THE BEAST
    Droid 4
    Droid 3
    -Isaac-
    Quote Originally Posted by isaacdibb1095 View Post
    no way of fixing it then?
  4. #4
    carracerz14's Avatar
    Posts
    ROM
    Arctic HD
    What recovery are you using
    Sent from my RAZR MAXXIMUS
  5. #5
    bradenfontaine's Avatar
    The Mad Man
    Posts
    Global Posts
    2,231 Global Posts
    ROM
    Black Widow
    Go download matts 1.8 utility and use option 1...
    Sent from my DROID RAZR using Tapatalk 2
    If i have ever helped you, please do not forget to hit Thanks
    If you ever have any questions about rooting we have written up a nice little thread HERE, please read this and post if you have any questions.
    If you need directions on how to clear your Cache, i have a write up HERE
    Thanked by:
  6. #6
    The Mad Man
    Posts
    Global Posts
    2,231 Global Posts
    ROM
    Black Widow
    Quote Originally Posted by carracerz14 View Post
    Hopefully he read the directions and is using safestrap
    Thanked by:
    I was using safestrap but i can't get on it, im stuck on the normal recovery.
    ---------- Post Merged at 07:57 PM ---------- Previous Post was at 07:56 PM ----------
    Quote Originally Posted by bradenfontaine View Post
    dont i need to be on AP Boot loader to use that? i can't get to that
  8. #8
    Posts
    ROM
    Arctic HD
    Have you tried using power and volume down to get it to reboot?
    If you're in the stock recovery isn't there a reboot option?
    yes but it wont reboot. it goes right back to the recovery
  10. #10
    The Mad Man
    Posts
    Global Posts
    2,231 Global Posts
    ROM
    Black Widow
    You should be able to still get into the AP Fastboot if you can get into the stock recovery.
  11. Thread Author  Thread Author    #11
    i finally got it to AP Fastboot. downloading utility 1.8 right now, but taking for ever
  12. #12
    The Mad Man
    Posts
    Global Posts
    2,231 Global Posts
    ROM
    Black Widow
    It is a rather large file. Go get a beer...
    Thanked by:
  13. Thread Author  Thread Author    #13
    after its downloaded I just use option 1 right?
  14. #14
    Posts
    ROM
    Arctic HD
    Yep, the one that says return to stock ics. Be sure to continue when it says press any key to wipe data or exit to keep it.
    Since you are coming from another rom and trying to restore, you will need to wipe data or you won't boot up
  15. Thread Author  Thread Author    #15
    I did it on my other lap top which all ready had utility on it, ( i forgot lol) but i ran the software till it said to wipe it, which i did. now i can reboot it right?
    ---------- Post Merged at 08:56 PM ---------- Previous Post was at 08:46 PM ----------
    I got it working again. Thank you both for help. Thanks a lot, i was freaking out.
    Thanked by:
  1. Need Help ASAP please
    By chuckawd in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 05-26-2012, 05:41 PM
  2. FOTA wipe failed- need help asap please
    By da blind in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 10-10-2011, 01:07 PM
  3. I need help asap please!!!
    By Youssef7 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 02-15-2011, 05:18 PM
  4. I need help asap please!!!
    Last Post: 02-13-2011, 10:49 PM
  5. need HELP...ASAP
    By AuxiliaryPie in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 04-24-2010, 06:38 AM
