Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By MichaelBR
  • 1 Post By carracerz14
    leesrt's Avatar
    Posts
    Global Posts
    103 Global Posts
    ROM
    2.3.6
    Default Problems with GPS
    Ever since the update I've had problems with my gps. When I use Nav it takes 5to 10 minutes for it to locate satellites no matter where I am. It worked fine before. Any suggestions.
    Sent via mental telepathy.
    Droid Razr Maxx 2.3.6
  2. #2
    Default Re: Problems with GPS
    Some others that have had the issue talk about doing a factory reset... check out Gps thread.
    Samsung Galaxy S4
    Droid Razr Maxx, HTC Thunderbolt, HTC myTouch 4G (Retired)
    Blackberry's 8900 to Bold (Retired)
    Flames Wallpaper
    Jerry: "Love, Peace, and Chicken Grease!!!"
  3. #3
    MichaelBR's Avatar
    Posts
    ROM
    Android 2.3.4 :-(
    Since the Android uses A-GPS (Assisted GPS), it will lock a position faster if there's connection to the Internet (or maybe even just to a network). I suggest you update the A-GPS data once in a while. That can be done by turning on the GPS and some app that uses it, while connected to the Internet.
    An easy way to do it is to do so manually. Apps such as GPS Status can download it for you on demand.
    bradenfontaine likes this.
  4. #4
    carracerz14's Avatar
    Posts
    ROM
    Arctic HD
    Best suggestion, ROOT.
    And then do this,
    9th comment
    Thanked by:
  1. Problem with GPS
    By Bobberta in forum Acer Iconia A100
    Last Post: 10-29-2012, 01:24 AM
  2. navigation having problems with gps
    By onlyoneromeo in forum HTC EVO 4G
    Last Post: 05-28-2011, 10:03 PM
  3. [APP] Look here if you have problems with gps
    By neo1691 in forum Android Applications
    Last Post: 05-20-2011, 09:27 AM
  4. confused as to why people are having problems with gps?
    By tropolis in forum Verizon Fascinate
    Last Post: 11-15-2010, 05:45 PM
  5. Google Maps loading problem with GPS-Need help.
    By arcane#ac in forum HTC Hero
    Last Post: 12-13-2009, 05:18 PM
