Results 1 to 5 of 5
Like Tree3Likes
  • 2 Post By bblaze
  • 1 Post By scotts9219
    Default Suspect Battery?
    So when I first got the phone when it was released I was getting 24 hrs plus of battery life. Now I'm lucky to get to 18 hrs. I'm not a heavy user of the phone; occasionally browse the Internet, mostly txt, and some pictures. My battery info says my display is at 72%.. Is that normal? The second highest % is the OS at 11%, everything else is <7%. Brightness is on auto.. Any suggestions?
  2. #2
    bblaze's Avatar
    Android Powered Human
    Posts
    ROM
    Stock ROM / Rooted Kernel
    Default Re: Suspect Battery?
    You can try using something like Juice Defender to help automate battery saving features. It may have something to do with what applications you have installed pulling down mobile data and eating up the battery life. It could also be the location you are in, if you get poor reception, the radio will be working harder to find signal. A battery saving app like Juice Defender may help out a bit. Also try switching to WiFi when you are in an area where WiFi is available to you, that will save some battery life, as well.
    ____________________________________________________________
    If I've helped, feel free to hit that "THANKS" button. It will make my day!
  3. #3
    bradenfontaine's Avatar
    The Mad Man
    Posts
    Global Posts
    2,231 Global Posts
    ROM
    Black Widow
    i can vouch for Juice Defender Plus, i can go for multiple days off one charge and yes, i use my phone for everything you would a PC.
    If i have ever helped you, please do not forget to hit Thanks
    If you ever have any questions about rooting we have written up a nice little thread HERE, please read this and post if you have any questions.
    If you need directions on how to clear your Cache, i have a write up HERE
    Thanked by:
  4. #4
    You might have to assume your carrier might have made some changes to the towers in your area. The radio has to run at a higher output to keep contact with the towers in fringe areas.
    Check your apps. I use SystemPanel to watch for rogue apps.
    bradenfontaine likes this.
  5. #5
    Same issues here. Juice defender did not help. Some days it goes till 11 pm, others til 8 pm. With the same use too. And I'm probably on wifi about 75 percent of the time. Still better than my X though.
    Sent from my DROID RAZR MAXX
  1. Battery life terrible?
    By bilobi in forum T-Mobile G1
    Last Post: 04-02-2013, 01:48 PM
  2. Battery draining like crazy. com.motorola.service.main suspected
    By utupelo in forum General Help and How To
    Last Post: 11-07-2011, 11:35 AM
  3. Improving Battery Life on Your Android Device
    By ERDude in forum HTC Hero
    Last Post: 02-04-2010, 12:33 PM
  4. Battery Length
    By wolf1989#AC in forum HTC Hero
    Last Post: 10-16-2009, 02:10 AM
  5. problems with camera and battery
    By piper09 in forum HTC Hero
    Last Post: 10-11-2009, 05:45 PM
