- 11-19-2012, 01:28 PM
Thread Author #1
Keyboards not working--help!
My keyboard now just stops working seemingly randomly. This has been happening since the afternoon of either Thursday 11/15 or Friday 11/16. It does not matter what keyboard app I'm using. I normally use Swiftkey, but this also happens with Swype and the standard keyboard.
The keyboard pops up and the keys respond to the touches (i.e., key changes color and enlarged briefly, or whatever the relevant indicator is on whatever keyboard I'm using) but (a) no text appears in the input boxes, and (b) no word predictions pop up. Sometimes rebooting the phone fixes the problem, but sometimes it does not, and the problem has ultimately come back every time. The touchscreen otherwise works fine--it seems clear that this is purely a software issue.
It doesn't matter what app I'm trying to type into--though I've noticed that sometimes I can bring the keyboard back to life by opening Facebook and trying to type in there. I assumed that meant that Facebook was the problem, but the Facebook app hadn't been updated for awhile when this started happening, and uninstalling Facebook didn't fix the problem.
I downloaded the Addons Detector app for the purpose of identifying apps that were recently updated, thinking that doing so might help me identify other recent app updates that may have caused the problem. But even after rolling back or uninstalling anything that had been updated recently, the problem persists.
The only other clue I have about this is that the keyboard issues have been coupled with severe battery drains. My battery used to drain about half way on a normal full day's use (15-18 hours or so). Since this issue started my batter drains fully before the workday is over (10 hours, max).
Help! - 11-19-2012, 01:41 PM #2
Re: Keyboards not working--help!
Have you tried (1) rebooting, or (2) clearing the data from the Motorola Input, Swiftkey, and Swype apps in Manage Apps?
- 11-20-2012, 03:14 PM #3
any luck on what B. Diddy suggested?
- 11-20-2012, 03:46 PM #4
Op posted at Android forums also, hasn't responded there yet either. I suggested that if the above doesn't work then a factory reset my be in order.
It's strange that it does it for every keyboard you use, makes me think there may be something going on in the background that a reset would take care of.
Try rebooting and clearing cache/data for the keyboard as B Diddy suggested first
Sent from my RAZR MAXXIMUS
- 11-21-2012, 11:16 AM
Thread Author #5
I've tried rebooting, and sometimes that works but sometimes doesn't. Clearing keyboard data did not work.
I agree that it must be something in the background--but what?! Haven't had time to do a factory reset yet, and would obviously prefer not to. But if the problem doesn't resolve I guess I will give it a shot over the long weekend. - 11-21-2012, 11:48 AM #6
Honestly I don't know what it could be. Idk what apps you have etc. I would do the reset when you get time.
- 12-05-2012, 08:44 PM #7
Hebrew Keyboard not working... Help please
By abenp in forum Sprint Galaxy Note 2Replies: 5Last Post: 02-12-2013, 01:45 PM -
SwiftKey Not work, help please!
By Punkidish in forum HTC EVO 4GReplies: 3Last Post: 07-14-2010, 10:02 PM -
Press and Hold Feature on Keyboard not working
By naybag in forum HTC EVO 4GReplies: 17Last Post: 07-09-2010, 06:11 AM -
Landscape keyboard not working with Seidio Innocase.
By mjesenovec in forum Motorola DroidReplies: 8Last Post: 02-07-2010, 02:33 AM -
Internet Not Working - Help Please?
By thezob101 in forum General Help and How ToReplies: 2Last Post: 10-30-2009, 09:03 PM
Reply
