Is there any battery widgets that display in the notification bar?
Thank you very much in advance.
I do own BW but they do not have this feature.
Re: Is there any battery widgets that display in the notification bar?
The GSam Battery monitor. It also lets you see what apps are draining your battery the most. Check it out right [Only registered and activated users can see links. Click Here To Register...].
Power Toggles is a great, versatile app that includes a notification bar widget with a battery level.
If you just want a battery widget, try Battery Circle.
Sent from my DROID RAZR using Android Central Forums
I like using battery indicator. It's free and has battery level at one percent.
Take a look above my notification bar. In AOKP you can have a battery bar above your notifications.
Sent from my DROID SPYDER using Tapatalk 2
I use Gauge Battery Widget. It shows 1 percent battery increments as well
ZDBox has a battery widget that displays on the notification bar.
Battery HD works for me. Note the 92% battery power in the notification bar (after 6 hours unplugged)
power toggles is great. I like having it pinned to the notification bar.
+1 for Gsam battery monitor (formerly badass battery)
Sent from my RAZR MAXXIMUS ;)
How is that possible, I'm unplugged for 2h 50 m and i'm @ 90%.... :(
Sent from my DROID RAZR using Tapatalk 2
I was down to 92% after 6hrs because I was sitting at work, not using the phone much and on WiFi. On the weekends, I tend to drain the battery faster since I'm not sitting behind a computer all day and tend to be running around, using 4G, using Google Maps, checking e-mail, surfing the web and playing Angry Birds. 90% after 2h 50m sounds normal
You can see from this chart that there's a big difference on battery drain depending on how much I use my phone. The left side is Sunday, when I use the phone heavily, vs the right side which is Monday - when I spend half the day at work, and then tend to drain it more in the evening after work:
