1. jb81868's Avatar
    I have had the razor max for awhile the 4g was great but now it is dropping like crazy i go from 4g to nothing is this the phone or is it the 4g network?
    Sent from my DROID RAZR using Android Central Forums
    12-13-2012 07:09 AM
  2. B. Diddy's Avatar
    Probably the network. Can you compare with other people on the same network? If they aren't having trouble, try rebooting your phone.
    12-13-2012 12:13 PM
  3. durango992007's Avatar
    Take it to Verizon and get a new sim card. My phone was doing this also at one point. Turns out the sim card was crap so they replaced it. No problems since.
    I just Flicked that message to you via my MAXXed out RAZR
    jb81868 likes this.
    12-13-2012 10:11 PM
  1. should I upgrade to razor hd max from razor
    By pnico in forum Droid RAZR MAXX HD
    Last Post: 11-29-2012, 06:14 PM
  2. Color change for keyboard..razor max
    By Candy8aloha in forum Droid RAZR MAXX
    Last Post: 04-24-2012, 08:20 PM
  3. razor signal drops
    Last Post: 04-23-2012, 06:10 AM
  4. signal bar up and down / spacebar question
    By DougFNJ in forum Motorola Droid
    Last Post: 11-08-2009, 08:34 PM
  5. signal icon question (telus)
    By kriEv in forum HTC Hero
    Last Post: 11-07-2009, 12:54 PM
