1. speedfreek64's Avatar
    Is there a way to link another folder to the menu that comes up when attaching audio to a text? I've got a custom folder loaded with my funny sound bites and I want to be able to access it when texting. Right now all my sound bites and music get lumped together which makes finding the exact sound bite a real pain. Hopefully someone has an answer!
    01-15-2013 09:07 PM
  2. MrHost's Avatar
    You can install es file explorer and then you can browse to the folder and file of your choice.
    Sent from my DROID RAZR using Android Central Forums
    01-15-2013 09:46 PM
  3. speedfreek64's Avatar
    Thanks! Just what I was looking for! I was going nuts trying to figure a way to solve this!
    01-15-2013 10:24 PM
  1. need help with recieving text please
    By staniswraith in forum Introductions
    Last Post: 01-28-2012, 02:00 PM
  2. need help with text messaging!!
    By mranbel in forum HTC EVO 4G
    Last Post: 11-10-2011, 06:29 AM
  3. Replies: 5
    Last Post: 02-18-2011, 08:55 AM
  4. Need Help with Texting App for Droid X
    By tbird669 in forum Motorola Droid X
    Last Post: 08-08-2010, 07:02 PM
  5. Need help with texting issue after I updated to 2.1.
    By Boztris in forum HTC Droid Eris
    Last Post: 05-16-2010, 03:14 PM
