Results 1 to 5 of 5
    Default Poor Battery Life?
    I have the razr maxx and ever since I got it I have never gotten amazing or even great battery life. I use my phone just as much as Any normal average user and have even done a fdr to try and help it. I get about 12-15 hours a day on average, which is pretty awful for a phone that is supposed to have one of the largest phone batteries ever. And suggestions?
  2. #2
    carracerz14's Avatar
    Posts
    ROM
    Arctic HD
    Default Re: Poor Battery Life?
    Yeah, try a galaxy nexus a use it the same and see what you get.
    Then you won't complain
    Sent from my RAZR MAXXIMUS
    Well, froma phone that is broadcasted to have 21 and up hours of talk time, I expected a little more. And I know for a fact that there are people with the razr maxx who have had much better battery than me and I know I am not getting the best battery life from my phone. I would like for my phone to last throughout the day, which it sometimes can't do, yet the Galaxy s3 usually can. Some actual help would be appreciated.
  4. #4
    Posts
    ROM
    Arctic HD
    How does 15 hrs not get you through the day? Turn your wifi off when you aren't connected, and use it whenever you can.
    I keep mine on auto brightness and wifinat home and work. Right now I have 48 percent left after 10 hrs and 44 mins with 2 hours of screen on time.
    Sorry bout your luck.
  5. #5
    There are a lot of existing threads about this. Things to try include:
    1. Wiping the cache partition from the bootloader. This seemed to help a lot of people after the ICS update.
    2. Turning on wifi, Bluetooth, or mobile data only when you need it. Try Power Toggles for a handy and versatile toggle bar widget.
    3. Turning off background sync (which can also be done easily using Power Toggles).
    4. Changing automatic refresh to manual in any app where you really don't need it done automatically (like Facebook, Pulse, Currents).
    5. Checking your battery stats to see if there are any apps in particular that are using an inordinate amount of battery.
    6. Using static instead of live wallpapers. Certain live wallpapers use more battery than others--you just need to try them out to see.
    In regard to the boasts of 21 hour talk time, you have to keep in mind that those are test conditions, where the display is probably not on. Display eats up the most battery, so if you're doing something that requires the display to be on a lot (especially if there's a lot of processor-heavy activity like gaming), your battery will run down faster. I've found that on my Maxx, I can get a little over 6 hours of total screen time on a full charge, which is considerably better than phones with an average battery, where it's more like 3-4 hours.
    Sent from my ASUS Transformer Pad TF300T using Android Central Forums
  1. Very Poor Battery Life...
    By techno_techie in forum Verizon Fascinate
    Last Post: 08-20-2011, 10:50 PM
  2. poor battery life
    By SpaceMuffin in forum LG Ally
    Last Post: 05-30-2011, 11:09 PM
  3. Poor battery life all of the sudden
    By nickpoz in forum HTC EVO 4G
    Last Post: 01-25-2011, 10:55 AM
  4. Really Poor Battery Life?
    By sixstorm in forum Motorola Devour
    Last Post: 10-06-2010, 10:30 AM
  5. If you have poor battery life try this!
    By Gekko in forum HTC EVO 4G
    Last Post: 06-08-2010, 03:58 PM
