Results 1 to 6 of 6
    Default Volume issue
    9/10 time I use YouTube there is no sounds. Volume is all the way up, I try to reload the video, anything I can think of and I still have the issue.
    Anyone else have this issue or know a fix?
    Sent from my ADR6400L using Tapatalk 2
  2. #2
    Default Re: Volume issue
    Do you have any sound at all? There's a frequently reported bug where all sound (including ringtones and notifications) stops. You can often wake up the sound by going to Settings/Sounds and selecting any ringtone, which will then play.
  3. #3
    If you are accessing YouTube with the actual YouTube app then try clearing the apps cache and data.
    -bob
    Sent from my SCH-I605 using Android Central Forums
  4. #4
    All you have to do is go back to the home screen, hit volume up (it will make a sound) then go back to YouTube. I've had 4 Maxxs and they've all done this same thing. Hell, the wife's bionic does it too.
    Sent from my DROID RAZR using Android Central Forums
    Thanked by:
  5. #5
    Maybe moto should have included these"special volume fix instructions" as the majority of razrmaxx owners probably don't visit forum sites. My next phone will not be a motor.
  6. #6
    docdfour's Avatar
    Posts
    Global Posts
    50 Global Posts
    I've found you can also "wake up" RAZR sounds from any app (YouTube, music player, video player) by taking a screen shot (hold power and down volume for a few seconds) How that gets fixed with muh jelly beans!
    Sent from my DROID RAZR MAXX using Android Central Forums
  1. volume issue
    By justinisloco in forum Motorola Xoom
    Last Post: 03-22-2011, 07:10 PM
  2. Navigation Volume issue
    By fstbusa in forum Verizon Fascinate
    Last Post: 01-21-2011, 01:42 PM
  3. Ringtone and volume issues --it's time to be heard.
    By ghamden in forum Motorola Droid X
    Last Post: 08-23-2010, 03:48 PM
  4. New media volume issue...
    By stuck804 in forum Motorola Droid X
    Last Post: 07-24-2010, 12:36 AM
  5. How will they fix the volume issue?
    By mattera68 in forum Motorola Droid X
    Last Post: 07-20-2010, 05:04 PM
