Results 1 to 12 of 12
Like Tree3Likes
  • 3 Post By cole2kb
    Default Girlfriend needs phone help..
    My girlfriend is updating from a Droid 3 to either a S3 or MaxxHD. Which would you guys go with and why or why not?
    Thanks,
    Isaac
    Sent from my DROID RAZR using Android Central Forums
    Razr Maxx- THE BEAST
    Droid 4
    Droid 3
    -Isaac-
  2. #2
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,026 Global Posts
    ROM
    Stock
    Default Re: Girlfriend needs phone help..
    It is hard for anyone to make recommendations that will be relevant to you. What is important to her? Durability? Style? Battery life? Best thing she can do is go to the store and play with both. Get the one she likes best in store, try it out, and take advantage of the 14 day return / exchange window.
    Sent from my dirty rainbow unicorn Nexus 7 using Tapatalk HD (HorriblyDeveloped)
  3. #3
    jeffrok's Avatar
    Posts
    Global Posts
    612 Global Posts
    ROM
    Stock
    The S3 is ultrathin and light, but its battery life is not nearly as good as with the Razr Maxx HD.
    The screens are very similar, and I believe they're both good phones other than the battery life.. Have her go to the Verizon store and play with each phone.. Also have her keep in mind that if she can wait a few months, the Galaxy S4 will be out, and it is said to be even better than the S3.
    I myself am a Motorola fan, and think their phones are built tougher. If a tough phone with great battery life is not as important to her, and "fashion" is, then get the S3 or S4.
    She went with the S3 and I am jealous. Damn my Maxx has gotten outdated.
    Droid 4
    Droid 3
    -Isaac-
  5. #5
    p08757's Avatar
    ** Superhero **
    Posts
    Global Posts
    1,936 Global Posts
    Quote Originally Posted by isaacdibb1095 View Post
    Load the new Jelly Bean update that just dropped to the soak testers today.
    Quote Originally Posted by p08757 View Post
    How do I go about getting it?
    Droid 4
    Droid 3
    -Isaac-
  7. #7
    MrHost's Avatar
    Posts
    ROM
    Gingerbread
    Go to Google framework services under app manager clear cache/data, force close. Check for update. Retry a couple times if it doesn't work the first time. Let us know if you had luck with it. Sometimes, it just hasn't been released in your block and no way around that.
    This assumes you checked for update already.
    Sent from my Xoom using Android Central Forums
  8. Thread Author  Thread Author    #8
    Quote Originally Posted by MrHost View Post
    That didn't work:/
    Droid 4
    Droid 3
    -Isaac-
  9. #9
    p08757's Avatar
    ** Superhero **
    Posts
    Global Posts
    1,936 Global Posts
    Been out for a while. Use one of these 2 links depending if you got the Dec 24th OTA or not:
    If you did not load or get the Dec 24th OTA
    If you did get or load the Dec 24 OTA
    Good luck!
  10. #10
    MAXX HD - The battery on the S3 sucks.
    Thanks,
    Isaac
  11. #11
    I'm upgradingt to G note 2, wayyy better then both of these phones
  12. Thread Author  Thread Author    #12
    Ive got it now, Thanks!
    Droid 4
    Droid 3
    -Isaac-
  1. Think I need some help, my phone may be screwed.
    By Proletariat in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 04-29-2011, 03:59 PM
  2. New to the forums and need phone help
    By Bobaganoosh in forum Introductions
    Last Post: 04-25-2011, 07:51 AM
  3. Phone pseudo bricked - really need some help (hopefully from thefredelement)
    By hgelpke in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 03-31-2011, 05:05 PM
  4. I need some help with phone signal....
    By bamaatheart in forum General Help and How To
    Last Post: 03-06-2011, 07:12 AM
  5. Replies: 5
    Last Post: 12-11-2010, 02:12 PM
