Results 1 to 9 of 9
    Default Data usage monitoring issue
    Has anyone else noticed this? I am running the leaked 4.1.2 from Christmas and it works fine but check this out. My data usage says 1.14gb yet it is trying to day that Netflix has use 1.98gb? Based on what YouTube says too it looks like it is doubling data usage per app but registering the total correct.
    (I know the total is correct because my Verizon app shows that number too. I will post a photo of that too once I edit out my phone number.)
    I don't know if this is a Jelly Bean thing or a razor thing. Mine is Maxx BTW.....very weird nonetheless.
    Sent from my DROID RAZR using Android Central Forums
    Attached Thumbnails Attached Thumbnails Data usage monitoring issue-uploadfromtaptalk1362581406719.jpg
  2. Thread Author  Thread Author    #2
    Default Re: Data usage monitoring issue
    Attached Thumbnails Attached Thumbnails Data usage monitoring issue-uploadfromtaptalk1362581625027.jpg
  3. #3
    MrHost's Avatar
    Posts
    ROM
    Gingerbread
    The 1.98GB usage is for a month period. It shows that in the pic you have posted.
    Quote Originally Posted by MrHost View Post
    Are you suggesting that the apps don't follow the same schedule as what you set it up for? I understand that all of the data is for a month period but both the total and what I have the data usage set at is with my billing cycle.
  5. #5
    MrHost's Avatar
    Posts
    ROM
    Gingerbread
    Ignore if read it already. I see the dates now.
    Sent from my Xoom using Android Central Forums
  6. #6
    MrHost's Avatar
    Posts
    ROM
    Gingerbread
    The difference is what data was used on WiFi. Data usage monitors both connections not just 4g/3g. When I look at my zoom my WiFi is monitored but I don't have mobile data on that. Looking at my maxx I can select to monitor WiFi too. If you look at data usage and hit menu does it give you option to monitor what you want. Mine does on ICS.
    I am monitoring only mobile data there. Notice the tab is blue underlined. Wifi usage is the other tab...
  8. #8
    MrHost's Avatar
    Posts
    ROM
    Gingerbread
    If you click on the other tab is the information reflected differently?
    The little note stating ,this is what your carrier used ,makes me think that.
    Yea it is. It is actually on a totally different cycle too.
    The info is totally. Different
  1. Data Usage Monitor
    By Speedstr in forum Droid RAZR MAXX
    Last Post: 04-08-2012, 04:09 PM
  2. Need the best 'data usage' monitor for 4G Skyrocket
    By Chevy-SS in forum Samsung Galaxy S II Skyrocket
    Last Post: 04-04-2012, 11:07 AM
  3. Data usage monitoring now on VMU website
    By Dannemand in forum Virgin Mobile Optimus V
    Last Post: 04-01-2012, 05:24 PM
  4. Data Usage Monitor
    By sam_soren84 in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 03-16-2012, 12:04 AM
  5. What's the best data usage/monitor app?
    By Bob Brown in forum AT&T ATRIX
    Last Post: 12-27-2011, 08:38 PM
