1. awriternot's Avatar
    I got JB with the soak.... I can't figure out how to set speed dial. Did they remove that feature & if so, wth? Why?
    Sent from my Unrooted Droid Razr Maxx Using Tapatalk
    03-09-2013 04:37 PM
  2. B. Diddy's Avatar
    Yeah, looks like Speed Dial is toast. I imagine they felt it was redundant, and is an archaic holdover from feature phones. You can always make your speed dial contacts into Favorites, or just place them on the homescreen as direct dials.
    Sent from my DROID RAZR using Android Central Forums
    PeninaD likes this.
    03-09-2013 04:42 PM
  3. rlanger271's Avatar
    You can also collect all those direct dials into a folder, and then it's just like speed dial, except now you're not limited to nine numbers, and you don't have to remember who got assigned to what number.
    awriternot likes this.
    03-18-2013 11:27 AM
  4. carracerz14's Avatar
    Yeah. Speed dial is kinda old school anyway. I didn't know people still used it.
    Sent from my RAZR MAXXIMUS
    03-18-2013 11:18 PM
  5. frdstang90's Avatar
    I used the speed dial before the jelly bean update but now I have the direct dial set up and I like it better.
    03-19-2013 07:49 AM
  6. jeffrok's Avatar
    There are also dialer/contact apps in the play store that you can make your default dialer.. There's at least 2 good ones that I know of, because I used to use them when I had a Nexus S 4G.
    03-19-2013 03:53 PM
  7. vndlewis's Avatar
    Is there anyway to make my phone open to favorites like it use to? I have butt dialed too many people since the update.
    03-19-2013 04:29 PM
  8. jeffrok's Avatar
    I've never butt dialed with a smart phone before.. Are you shutting the screen off before you put it in your pocket?
    03-19-2013 10:07 PM
  9. MrHost's Avatar
    Code lock or use pattern lock see your butt pass that security heck use facelock too many options. Pattern lock is the easiest.
    Sent from my Xoom using Android Central Forums
    03-19-2013 10:26 PM
  10. vndlewis's Avatar
    Yes, I shut the screen off and sometimes before I put it in my pocket I am calling someone else. I will pull my phone out of my pocket and it is already dialing someone.
    The other day my husband had charged his phone all night. When we got up, his phone had dialed about 20 people and sent out about that many text messages on it's own. Don't know what is going on, but not liking it.
    03-20-2013 06:01 PM
  11. Rogus's Avatar
    Seems to me, if you use facelock and your butt still is able to dial the phone, you have bigger troubles than we can help you with...
    03-20-2013 07:38 PM
  12. MrHost's Avatar
    Lock with code if it still happens, return under warranty..or do it anyway.
    03-20-2013 09:15 PM
  1. Speed Dial?
    By cward0625 in forum Motorola Droid
    Last Post: 11-07-2010, 09:21 AM
  2. speed dial option ?
    By cmysho in forum Motorola Droid
    Last Post: 01-22-2010, 09:49 PM
  3. Speed Dial
    By smccloud in forum HTC Hero
    Last Post: 01-17-2010, 08:22 PM
  4. Replies: 1
    Last Post: 11-28-2009, 12:53 PM
  5. Speed Dial
    By wysiwyg in forum HTC Hero
    Last Post: 10-15-2009, 04:33 PM
