Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By docdfour
    docdfour's Avatar
    Posts
    Global Posts
    50 Global Posts
    Default WiFi connection issues after JB
    I was having issues initially with my WiFi disconnecting frequently after the JB install until I found the following setting, and it's made all the difference. Go to Settings/WiFi
    then hit menu and go to Advanced,
    then un check Avoid poor connections.
    Parts of my house bounce between 1-2 bars on WiFi, but I never lost connections before JB. I'm just glad changing the setting worked for me. Hope it helps others out too!
    Sent from my DROID RAZR MAXX using Android Central Forums
    Attached Thumbnails Attached Thumbnails WiFi connection issues after JB-uploadfromtaptalk1363294720530.jpg   WiFi connection issues after JB-uploadfromtaptalk1363294765133.jpg
    Thanked by 3:
    covard likes this.
  2. #2
    Default Re: WiFi connection issues after JB
    One of my favorite things is in this same menu, and that's "to notify me when an open network is available".....mine was unchecked which is great since I hated seeing that question mark all the time when it found a network on ICS.
  3. #3
    Used wifi last night at a sports bar without any issues.
    Sent from my DROID RAZR using Android Central Forums
  4. #4
    My spouse was having the same issue with the wifi shutting off and the phone going to the 4g signal around our house. I went into the advanced settings and changed as the original poster said. Thanks, so much.
  5. #5
    Quote Originally Posted by covard View Post
    Same here but I am very concerned about the phone saying that the WiFi connection is poor when I'm sitting right next to my router. I now see one bar most of the time in the house where prior to the JB update I would see 2-3 consistently.
  1. Clear WiFi connectivity issues after 4.2 Update
    By Joseph Best in forum Google / Samsung Galaxy Nexus
    Last Post: 11-22-2012, 11:09 AM
  2. WiFi Connection Issues After ICS
    By Pakbackr in forum Verizon HTC Rezound
    Last Post: 08-11-2012, 08:25 PM
  3. Wifi connectivity issues after 2.3.6 update
    By perrochingon in forum AT&T Galaxy S II
    Last Post: 02-13-2012, 01:51 PM
  4. wifi connection issue?
    By coldmack in forum HTC Droid Eris
    Last Post: 03-13-2011, 08:06 PM
  5. Droid X WiFi connect issue? Try this...
    By Dural in forum Motorola Droid X
    Last Post: 12-13-2010, 03:12 PM
