1. oceano11's Avatar
    So my Motorola charger was stolen, I ended up charging my RAZR MAXX for 3 days on my HP tablet charger. One day it was at 5% so I put it on the charger. All of a sudden it turned off and then displayed the charging screen with 0%. Is it possible that the tablet charger since it has more amps destroyed my phone??
    This phone doesn't have a removable battery, so I'm wondering if there is any other way I can salvage it. I lost my insurance this month because I forgot to update my credit card info and they won't let me renew my insurance unless I pay an annual lump sum fee of over $100, and will have to wait 30 days to file a claim.
    05-02-2013 04:50 PM
  2. eledarmi's Avatar
    One of my chargers was like that. the charger charged the phone just fine. Then I used another charger and it works fine. Did you try another charger?
    05-02-2013 10:46 PM
  3. B. Diddy's Avatar
    Maybe the charger you used actually didn't provide enough amperage, and your Maxx's battery subsequently died. You could try ordering a new charging block here (
    http://www.icemonkey.com/motorola-89...evices-at-once). You should be able to use any USB to microUSB cable. Plug it in for at least 24 hours straight, then try to turn the phone back on.
    Sent from my DROID RAZR using Android Central Forums
    05-02-2013 11:21 PM
  1. Android won't charge or turn on
    By hartmaynora in forum Android 4.0 Ice Cream Sandwich
    Last Post: 04-28-2013, 06:09 PM
  2. Phone won't charge and turns on when plugged in PLEASE HELP D`:
    By MrRec0very in forum T-Mobile Galaxy S Blaze 4G
    Last Post: 04-12-2013, 10:12 PM
  3. Installed cm9, now won't charge or turn on
    By Mazus in forum HP Touchpad
    Last Post: 12-27-2012, 05:19 PM
  4. Replies: 5
    Last Post: 01-01-2011, 01:52 PM
  5. MyTouch 3G Slide Won't Charge OR Turn On
    By cowhugging in forum General Help and How To
    Last Post: 12-08-2010, 01:40 PM
