Fake Motorola battery? (EB20)
youra6
So this thing fell out of my Atrix HD today... First thing I notice is that it was too small to fill up the back of the phone. Second thing I noticed was that is yellow and had no pull tab on the side.
One person I asked claimed that this was a battery for the Original Droid RAZR. Do you think its possible for a Manufactured refurbished phone to come with a Razr battery?
I don't think so, but what do you think?
Here is a link to a counterfeit battery that looks a lot like mine:
1750 mAh Battery for EB20 Motorola XT910 XT912 Droid RAZR Screw Driver | eBay
Mine looks like the one on the right.
jeffrok
577
21
I dunno if the battery is counterfeit, but if it's smaller than the original, I wouldn't trust it to stay in properly. If it slides around it might put wear and tear on the connectors.
pithypants
5
The connector on the one on the right looks just like the fake EB20s I installed in my RAZR MAXX. (Yes, I packed 2 EB20s in place of the EB40)
pithypants
5
I believe the MAXX has a 3300mah battery, doesn't it?
Mine came with a3200 mah battery which I wanted to replace because I think its capacity is about 30% diminished. The only reason I thought it might be worth putting in 2 EB20s was that I found some aftermarket ones on the cheap that were advertised to have a 3030 mah capacity each. I did get them both to fit in place of the EB40, but they were crappy batteries that failed to even take a charge after a few cycles so I put the original back in.
Laila Nance
