Android Forums at AndroidCentral.com >  Verizon Droid Forums >  Droid RAZR > Battery life tips and tricks
Reply
Like Tree11Likes
Thread Tools Search this Thread
  #41
Old 12-20-2011, 11:43 PM
Activity: 0/20
also lithium based battery cells do not need to be discharged fully EVER!...DOD or depth of discharge is a big factor in how long a lithium battery lasts. The less DOD, the more charge cycles you will get out of the battery. Charge your phone whenever you can. At 100% DOD a lithium battery will last around 500 cycles. at 60% dod a lithium batter will last closer to 2,000 cycles. You do the math.
BLLade likes this.
  #42
Old 12-28-2011, 08:18 PM
Activity: 0/20
How do you freeze apps?
Quote:
Originally Posted by robstunner View Post
Freezing some apps can help too, just make sure you freeze the right ones. I have the IM app as well as slacker/lastfm, and all the verizon video/ringtone apps frozen. Even if it doesnt help, at least you get rid of some of that app drawer clutter.
  #43
Old 12-28-2011, 08:26 PM
Activity: 0/20
I'm sorry to ask.... what is smart actions?
Quote:
Originally Posted by rickc1015 View Post
Me too. I had to disable background sync while my screen is off and enable when the screen is on in smart actions. Two separate actions. I use exchange email set to push, and simply tap the power button to check for new mail. Phone on overnight and my battery only dropped 4% using circle widget.
  #44
Old 01-05-2012, 01:13 PM
Device(s): Droid Razr, Xoom (Wi-fi)
ROM/Kernel: Stock
Activity: 0/20
Quote:
Smart actions is a program that is included in the Razr to help complete tasks for you when certain conditions are met. For example, turning off Cell data when connected to wifi. If you look in the app drawer it's there.
  #45
Old 01-07-2012, 10:38 AM
Activity: 0/20
Quote:
How is this different from what you can use Tasker to do? I haven't used tasker yet, but it seems like it should be able to accomplish this and more. Or, does the razr provide something unusual that you can't get on other phones even with apps like tasker or juice defender?
  #46
Old 02-03-2012, 11:14 AM
Activity: 1/20
So, had my Razr since Tues. Hoping that I get the "my battery is better after a week" syndrome. I'm at 20% after 3 hr.15 min. Admittedly, it's been fairly constant use, what with 10 minutes of Rhapsody, 5 minutes of Mobile Hotspot, frequent FB checking, and downloading a couple of toggle apps from Market (you can probably guess what they are!).
I was hoping for a little better. But, I will plan a little better as well, especially since I'll be using Mobile Hotspot at home a lot. I just wanted to see what the battery usage was like, so I left it off the charger. I'll be keeping it on the charger when at home. I think I'm going to disable 4g whenever I'm shopping mundane things like checking FB or streaming Rhapsody (unless I'm getting a lot of buffering
  #47
Old 02-03-2012, 11:17 AM
Activity: 1/20
Delete double post.
  #48
Old 02-03-2012, 09:12 PM
Activity: 1/20
Quote:
The math is a little misleading since you will obviously recharge more often if you don't let it discharge as much.
I'm not good enough with math to figure out the breakeven point, but it seems to me that you'd at the very least be recharging twice as often in the former scenario. So that cuts the gap by half. Right? I get your point though.
  #49
Old 02-21-2012, 08:46 AM
Device(s): RAZR XT912
Activity: 2/20
Just discovered that my live wallpaper was the reason for my rapid battery drain.
I had installed the Galactic Core (Donation version) live wallpaper
Kittehface Software
While looking at my top battery users, it didn't show the wallpaper, just that the Android OS was using 75% of my battery.
I turned off the wallpaper a couple hours before planning to head to the Verizon store to complain about poor battery life, but when I went to check my phone (which was losing 10% life per hour at Idle) it was still at full charge. I decided to give it another couple days before suffering the Verizon tech desk.
In a test, I left my phone off the charger over-nite and it still had 60% battery left this morning. Most times if I forget to charge my phone it is completely dead in the morning.
Looks good! Plus, it charges much more rapidly than when I had the wallpaper running.
I don't know if all live wallpapers will cause this issue or just the one I purchased
  #50
Old 03-01-2012, 11:32 AM
Activity: 0/20
I believe its all the live wallpapers. It really sucks we cantget the sprinkles on top of the ice scream
Sent from my DROID RAZR using Xparent Cyan Tapatalk
Reply
Search this Thread:
Advanced Search
