03-27-2013 01:32 AM
29 12
tools
  1. ebarr727's Avatar
    I did experience my first 'frozen phone' on my MAXX. For about one hour it remained on the locked screen and unresponsive to any screen interactions. I did the power button-down volume button combination and the phone did a soft reset after about 10 seconds or so of holding down both buttons.
    05-20-2012 08:22 AM
  2. suffolksystems's Avatar
    Hello guys I have the new thin droid razor in white, and its slow, does`nt respond sometimes.....I go into menu,system settings,privacy and reset phone and it wont do it. it just hangs............. The volume down power thing doesn`t do it either ..............Any ideas ???? Is there a factory RUU like the evos???
    ps im on 4.0.4
    build number 6.72-180_DHD-16_M4-31
    11-29-2012 01:47 PM
  3. Raven Carter's Avatar
    I have the Droid Razr MAXX and it had been frozen for about 6 hours and had gotten me super worried. I Googled it and stumbled across this website and I tried this trick and it unfroze almost immediately!! Definitely will be doing this again!!!
    12-11-2012 07:08 AM
  4. Mike Hagans's Avatar
    Holding down the power button and the down volume button for 10 seconds rebooted the phone and unfroze it. Thanks so much for this tip!
    03-27-2013 01:32 AM
29 12
