Results 1 to 9 of 9
- 11-17-2011, 04:52 PM
Thread Author #1
Help No Sounds from RAZR
My phone will not play any sounds from the internal speaker, no music, notifications, speaker phone or anything. It is not on silent mode, the volume is turned up, tried soft reset and ideas? Sound does come from headphone jack.
- 11-17-2011, 05:41 PM #2
Re: Help No Sounds from RAZR
Return it?
- 11-18-2011, 08:07 PM #3
Mine did that yesterday, too. I have three Google accounts synced to my device. After the new Music app updated, all of my sounds stopped. Deleting my two "extra" accounts, and re-adding them fixed the issue. The music app and the market both seemed to be trying to utilize the extra accounts rather than my main account before I did that. Hope it helps.
- 11-19-2011, 07:59 AM
Thread Author #4
I tried factory reset and about every other option I could think of. Turned out to be hardware problem. V switched out the phone for a brand new one without a question.
- 11-19-2011, 04:56 PM #5
- 04-24-2012, 05:31 PM #6
I just had this same exact issue. My story is one where I did the update last night before bed. When I woke up I had no sound from the speaker. Ear-piece worked fine, just nothing from the rear speaker. After messing with it all day, I finally did a factory reset. Still nothing. Called Verizon and they stated that it was a "known issue." They are sending me a brand new, not refurbished phone. Kinda mad because I bought this phone outright a few months ago and I thought I would be screwed for this. Anyone else having this issue? This is the first thread after doing a minor search on a few sites that I've seen someone else with the same problem.
- 04-25-2012, 04:02 PM #7
Same exact thing happened to my Razr Maxx. I think that there was a lose connection with the speaker, if I smacked the back of the phone while it was doing its silent thing it would work again for a random period of time.
When I called Verizon, after talking to 2 reps, they changed it out. - 04-25-2012, 09:26 PM #8
- 10-02-2012, 05:07 PM #9
Reply
