Results 1 to 5 of 5
    Default Misleading battery green light
    My battery is at 50% the green light indicator looks much more. Anyone concurs
    Sent from my DROID RAZR using Tapatalk
  2. #2
    androidcore's Avatar
    Posts
    ROM
    Rooted Stock ICS 6.14.84
    Default
    Same here... probably needs a battery recalibration. But on a new phone? Hmmmm... I use switch pro with its battery widget. So I'm good. Doesn't really bother me. Yet. Lol
    If I helped you, then please hit the "Thanks" and/or "Like" button(s). I like to know I'm not just here for amusement.
    **1998** Nokia 6160 > Samsung Color VGA1000 > Samsung T209 > Samsung SGH867 Eternity > Samsung I8000 Omnia 2 > Motorola MB810 Droid X > Motorola XT912 DROID RAZR **2012**
  3. #3
    epphllps's Avatar
    Posts
    Global Posts
    548 Global Posts
    Default
    It is very misleading. Was implying I had 50% battery when circle widget said 26%. When it hit 25% it dropped way down and was more accurate. Seems like it might work in blocks rather than actual remaining battery.
  4. #4
    Default Re: Misleading battery green light
    Like most Motorola phones it probably works on increments of 10 percent.
    C3H6N6O6 + (CH2)8(COOC8H17)2 + C4H8 + C5H8 = BOOM
    You don't shoot to kill; you shoot to stay alive!
  5. #5
    wckesq's Avatar
    Posts
    Global Posts
    300 Global Posts
    I use the battery left widget. It gets more accurate as you use it.
    WCK
