Results 1 to 7 of 7
- 11-26-2011, 04:55 PM
Thread Author #1
connectivity issue with the razor too?
hi,
I just sold my bionic on ebay..and was looking to get the razor and im reading that the razor has the same issue as the bionic.. loses connectivity..
I can still refund the money to the person who paid for my bionic..but am I in for a headache with the razor?
I have the bionic with extened battery. I found the razor attractive due to the scratch resistant material used and the nice screen..
aside of that I think they are pretty much the same phone..with the razor being a little upgraded..
I know from using other 4g devices that the battery dies fast. I use the phone a lot and I might get 6 hours out of it. The best 4g device I had used prior to the bionic was the charge..with a stock battery..not bad...but if I buy the razor and have the same data connectivity issue, Im going to be annoyed.
is it worth the upgrade to the razor for the screen/stratch resistance build.considering the hardware inside is more or less overclocked and its just prettier..not really a major step up..
thank you - 11-26-2011, 09:50 PM #2
Totally worth it
Sent from my DROID RAZR using Tapatalk - 11-26-2011, 10:49 PM #3
- 11-27-2011, 07:32 AM #4
Re: connectivity issue with the razor too?
I have only had mine a couple of days. I travel in and out of 4G areas all day long haven't dropped connection and have not noticed to much swithching from 4G to 3G. First day in 8 hours of moderate use battery dropped to 40%. I don't think that is to bad.
- 11-27-2011, 11:12 AM #5
- 11-29-2011, 12:21 PM #6
i compared my friend's razr side by side with my tbolt. while my tbolt barely held a weak 4g signal, the razr had trouble holding a weak 3g signal. i'll take my tbolt's signal strength any day.
- 11-29-2011, 01:18 PM #7
Reply
