I have seen the Android Central feed highlight three negative threads about the Droid RAZR, and now even the new chart Android Central is proposing for comparing phones misses the RAZR's defining feature. Why is the best thing about this phone a complete secret?
The Droid RAZR has Smart Actions, which allow the user to control the conditions under which the phone automatically does things. I use Smart Actions to maximize battery life. When I first got the phone I found myself having to recharge the phone two or three times per day -- horrendous battery life, per that Android Central thread highlighting the issue. However, I bought the phone knowing that it would give me fine control over battery life. So I set out to find the best way to do this.
Now my RAZR has the best battery life of any smart phone I have ever owned -- and this is my first LTE phone! I typically have 50% charge after 16 hours unplugged, with about two hours of talking and two hours of data use -- and I live in an area with LTE (Austin).
These are the Smart Actions that give me such good battery life:
Low Battery Saver - This Smart Action is a standard one that Motorola makes available. If the battery level is less than 20% and the device is not charging, the phone automatically sets the display brightness to 25%, turns off GPS, and disables background data synchronization.
Battery Extender - This is another standard one that Motorola makes available. If the display is off, the phone is not charging, and the phone does not detect motion, the phone automatically turns GPS off and disables background data synchronization.
Sleeping - This custom Smart Action is the magic trick for maximizing battery life. If the display is off, the phone is not charging, and it is 0 to 55 minutes after the hour, both cellular data (4G/3G) and background synchronization are disabled. In other words, LTE is kept off except when I need it. Data is only synchronized during a 5 minute window every hour, unless the display is on and I'm using the phone.
Wi-fi Only - This is another custom Smart Action. If I have a wi-fi connection and the phone is not charging, cellular data (4G/3G) is turned off. I don't really need to be wasting juice on 4G when I'm on wi-fi.
I've only found one drawback with this configuration. For some reason, to send a photo by text (MMS), I have to first enable cellular data. It won't do it entirely over wi-fi. Someone helped me solve this problem by suggesting that I get a wi-fi toggle button for the home screen. When I explicitly turn wi-fi off, the Smart Action sees that there is no wi-fi and automatically re-enables cellular data. I can then send the image. (Actually, the RAZR queues the MMS message and will complete a previous attempt to send it at this point.) Once sent, I just toggle wi-fi back on.
I had a heck of a time deciding what phone to buy prior to finding a description of the RAZR's Smart Actions hidden away in some obscure blog post. This feature sold the phone, and it has proven as fantastic in practice as it appeared to be in principle.
I don't understand why Motorola isn't making a big deal of this feature in their advertising. Hearing about it earlier would have saved me a lot of indecision headache.
Note: I just recently added the "not charging" condition to the "wi-fi only" smart action, but I'm finding that for some reason this condition prevents the action from ever triggering. Until Motorola fixes this apparent bug, this smart action should always trigger on the presence of a wi-fi connection, regardless of whether it is charging.
