problem with wifi widget
missouriexile
129
New member. had next. swapped for RAZR
because of. very bad signal problems.
just getting razr set up. u
I added the wifi on/off widget to my home screen. used it a couple of times.
then whatever app icon I pressed brought up the wifi screen.
had to power down and remove the widget to get app icons to work.
is this just me?
That's very odd. I have not had any issues with the toggle widgets.
Are you using the widget that came with the phone or one you downloaded?
Sent from my DROID RAZR using Tapatalk
slackingfred
