- 05-23-2012, 01:23 PM
Thread Author #1
Battery meter
Does anyone find that the battery meter is inaccurate? Mine looks like it should be 90% but settings say 75%.
Sent from my DROID RAZR using Tapatalk 2 - 05-23-2012, 01:58 PM #2
I stopped paying attention to the battery meter after I installed the battery solo widget. Helps out alot.
- 05-23-2012, 07:50 PM #3
That's in part of MOTOBLUR. Stock, I believe they only have so many "icons" to show a certain amount.
ie- some might have a set icon to show in increments of 5 percent. So this would look more accurate.
Some might be set to 15% increments causing the icon to seem misleading.
Sent from my DROID RAZR using Tapatalk 2 - 05-24-2012, 07:55 PM
Thread Author #4
Thanks for the insite. I downloaded the battery widget by macro pinch an it reads in 1% increments. According to the stock battery meter I have 50% battery left, according to the widget, 30%...
Sent from my DROID RAZR using Tapatalk 2 - 05-26-2012, 07:58 PM #5
Re: Battery meter
the picture is definitely front loaded, it always looks higher than it is
I downloaded charge bar which is a one pixel bar across the top of the screen that shows how much, I really like it and its free, u can also pick the colors to change at different percentages - 05-30-2012, 08:11 PM #6
- 06-02-2012, 02:23 PM #7
- 06-02-2012, 07:00 PM
Thread Author #8
Thanks. I'll try that tonight.
Sent from my DROID RAZR using Tapatalk 2 - 06-02-2012, 07:41 PM #9
- 06-03-2012, 07:45 AM #10
- 06-04-2012, 08:22 AM #11
- 06-04-2012, 10:23 PM #12
- 06-06-2012, 05:41 PM #13
Re: Battery meter
I used battery circle on my Droid X and it worked very well. I just downloaded that bada$$ Battery monitor and it too is very useful. I like the icon on the bar, and it extra information is kinda nice. Not half bad for another free app.
Follow me @Ahowe125 on Twitter| Limited Edition Razr Maxx | R3Ds PNuT.BuTTa and Urban Theme with Dual Boot on leaked JB Kernel |
Reply
