Results 1 to 5 of 5
    Cosigne's Avatar
    Posts
    ROM
    Debloated Stock .605
    Default ICS Audio Issues
    Is anyone else having problems with playing audio on ics? Be it music or video, I'll go to play something and even with the volume all the way up it no sound will come out. Notification sound and ringtone still work though. :/ A reboot fixes the problem temporarily... Any suggestions? I'm trying to avoid a factory restore, but that is probably the only solution...
  2. #2
    eoga's Avatar
    Posts
    Default Re: ICS Audio Issues
    I have a different problem related to sound to, not sure if ICS is the cause. Every time I connect the aux cable from my car or a headphones, I can listen the music and evertyhing seems to be working ok. but when I disconnect my phone I have no sound at all, no music, no ringtone, i can even heard the voice from a call. it is like if the phone think that the aux cable is still plug in when it is not anymore. I have to restart the phone every time i used the headphone plug, this is really annoyin. can any one help me?
  3. #3
    Default
    Quote Originally Posted by Cosigne View Post
    I have experienced the same problem. I also have done a couple of factory resets so I think that it it just a software bug. It has only happened 3 times in a week. I have been able to get sound to start playing normally by going into sound settings and sliding the sound slider back and forth.
  4. #4
    I had the same problem today. It happened twice, no sound in music or on you tube. My solution, went to settings sound and checked ringtone sound. Ringtone worked and then all of sound came back on player and you tube. very strange
  5. #5
    There is an app named SoundAbout in the Google Play store that may help.
