Results 1 to 10 of 10
    Default Voice recognition problem after ics
    After the ics download on razr, my brother is saying that he is having issues with voice recognition. He speaks then it continues to search for awhile without results. Anyone else run into that problem? If so, do you know how we can get it fixed?
    Sent from my ADR6425LVW using Android Central Forums
  2. #2
    Default Re: Voice recognition problem after ics
    I'm having the same issue...trying to work on a fix. I speak clearly, but the phone doesn't understand me.
  3. #3
    willymakit's Avatar
    Posts
    Global Posts
    934 Global Posts
    ROM
    stock
    Same problem here.
  4. #4
    I discovered this feature will not work for me when I am connected to my wireless network; however, it will work when I am only connected via 4G.
    Let me know if this works for others.
  5. #5
    Same thing here. Disable wifi and then it works instantly.
  6. #6
    Same here. It works fine when I disable wifi. But just keeps "working" when I don't.
    Default
    Thank you all
  8. #8
    I figured out on my phone to go to my wifi and tell it to forget my connection. Then I went back in and rather than connect directly to it I chose to ADD NETWORK in bottom right corner. In there put in the name of my WiFi connection (Network SSID), then put in the password and choose the correct security WPA/WPA2 PSK. Once I connected this way it fixed my issue. Hope this helps you! - Droid Razr MAXX
  9. #9
    I don't have this problem. I can speak into my phone right now and its typing it. I'm connected to wifi right now.
    Sent from my DROID RAZR using Tapatalk 2
    Verizon Motorola Xoom 4G
    Samsung Galaxy Tab 2 7.0
    Verizon Samsung Galaxy S3 Rooted
  10. #10
    Ever since the latest update voice recognition does not recognize any one in my contact data base. Further the latest interface has changed to the worst. Most frustrating. If this is not fixed real quick, off to Iphone I go. Tired of moronic updates.
