- 08-30-2012, 06:26 PM
Thread Author #1
- 08-31-2012, 12:27 AM #2
So far straight 5 star ratings. Looks good! :thumbup:
Sent from my RAZR MAXXIMUS
- 08-31-2012, 07:35 AM
Thread Author #3
- 08-31-2012, 02:18 PM #4
Re: AccuBatt: 1% Battery levels for Motorola Phones
Awesome!
- 08-31-2012, 03:14 PM
Thread Author #5
- 08-31-2012, 09:32 PM #6
Just installed this on my Bionic. First off, thanks for making this, because i never did like it only displaying 10% increments. Working well so far, but i have a minor suggestion. Could you add color change settings for the notification? Green on a black background of the notification bar makes it hard to read, especially with phone dimmed. Not to mention ICS changed the bar coloring itself, making notifications harder to read on my phone. I would prefer it to be white, and even that now looks grey on my notification bar. May also help to bolden the counter too to help it stand out more.
Edit: I had to reboot my phone to get the widget available in my list. Normally i don't have to do that.Last edited by Mooncatt; 08-31-2012 at 09:42 PM.
- 09-01-2012, 12:54 AM
Thread Author #7
- 09-01-2012, 01:50 PM #8
Maybe found another bug. The notification at the top shows me at 100%, but the widget shows me at 96%. I deleted the widget and re-added it, and now that says "ERR". I saw it say "ERR" before too and it eventually corrected itself. Tapping the widget to bring up the pop up window shows the correct info, and refreshing the app doesn't seem to affect it.
- 09-01-2012, 03:10 PM
Thread Author #9
Interesting...What phone / Android version are you running? I've never seen / heard of this occuring before...the "ERR" appears when the phone won't report the battery percentage..usually this means it has not booted up yet, or else Android has killed the service without restarting it.
Reboot should fix that 99% of the time, but it shouldn't have happened in the first place.Thanked by: - 09-01-2012, 03:16 PM #10
I'm running it on a Bionic with the leaked .232 version of ICS. I do know I've had some issues with either the USB cable or the port going bad (I loathed the day they decided to make USB the charging method, but that story is in another thread), where it now takes a long time to charge and will actually discharge while being pluged in with the charge indicator on. I don't know if that could have anything to do with it, but it's never affected my stock battery level monitor or another one I use in the Android Assistant app. Nothing is being FC'ed by the assistant app or any other meathod either that could make the phone stop that particular service.
- 09-01-2012, 03:23 PM
Thread Author #11
Well, my primary test device (my daily phone that I have this installed on) is the exact same as yours (Bionic .232) so I doubt it's device-specific. More likely, its something on your end. I would try clearing the cache of AccuBatt (This will cause you to lose your settings such as the fahrenheit toggle). And try rebooting.
- 09-01-2012, 03:32 PM #12
I didn't have to go that far. When I cleared the cache and data, I decided to re-open the app and see what happens. The widget then cleared the ERR and is reporting 100% now too. I don't remember exactly what started the issue, but seems if you have the app already running and THEN put the widget on your home screen, it causes the widget to ERR. It has to either be put on before starting the app, or FC and restart the app after the fact for it to report.
- 09-01-2012, 03:33 PM
Thread Author #13
- 09-01-2012, 03:36 PM #14
Any time.
If I find any more bugs, want me to post right away, or wait until the next release to see if they still exist? - 09-01-2012, 03:38 PM
Thread Author #15
- 09-01-2012, 11:33 PM #16
- 09-02-2012, 12:17 AM
Thread Author #17
- 09-02-2012, 01:33 PM #18
I'm using a Razr running ICS and the color you have chosen for the digits (a green colour) is very difficult to see. If you could change it to a brighter colour. Like the clock digits or something.
Thanks.
Sent from my XT910 using Android Central Forums - 09-02-2012, 02:49 PM
Thread Author #19
- 09-03-2012, 07:30 AM #20
- 09-03-2012, 10:10 AM
Thread Author #21
Unfortunately, the notification is stuck where it is, I can only place them in that area. As far as the color..that should be coming very soon.
I'm working on an In-app purchase that activates some new features and removes the ads. Originally the plan was to put the ICS theme in the extra features, requiring a purchase, but I'm reconsidering putting it back free.
It seems like a lot of people see the colors as a limitation, so I don't want to charge for a bugfix. What do y'all think? - 09-03-2012, 11:55 AM #22
- 09-03-2012, 12:34 PM #23
I would at least offer white. I think the ICS theme would be super slick, but I don't know if it'd be worth the price for that color scheme. I don't blame you for thinking of charging for it, but I think the only way to do it would be to lump it in with the other upgrades and ad removal. I wouldn't be willing to pay for the ICS theme by itself.
- 09-03-2012, 12:49 PM
Thread Author #24
- 09-03-2012, 02:39 PM #25
I did the update & got forced closes even after rebooting. After uninstalling & reinstalling the app it's just perfect so any problem seems to be in how the update itself is applied. The ICS (white) theme fits my needs just dandy. Again, good job & thanks.
Sent from my Droid RAZR MAXX using Tapatalk2
Reply
