Results 1 to 3 of 3
- 09-05-2012, 10:33 PM
Thread Author #1
Battery drainer so quick..after 11 hours its dead!
Very light use..I wipe format reinstall did all that
- 09-05-2012, 10:50 PM #2
When you do the wipe does it delete everything?? How/where do you back everything up. (I'm somewhat a newbie with Android, former BB owner) my phones a bit laggy after my ics update. Also how do you get to the part where you can wipe?
POW! Right in the kisser. - 09-06-2012, 07:10 AM #3
Re: Battery drainer so quick..after 11 hours its dead!
What is the screen on time? That should be your determining factor. I typically can get 2.5-3 hours and I am just stock rooted.
4G LTE Thunderbolt
Reply
