Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By carracerz14
    Default So **hypothetically**, let's say I tried to install Arctic with a low battery...
    Alright, that seems to be exactly what happened. But now the phone won't charge. The initial red M splash screen turns on when plugged into the wall, but it doesn't seem to charge. I'd left it like that all night, but it's still too low to use fastboot.
    How do I charge it?
    When plugged in with USA, it doesn't charge, but when plugged into the wall, fastboot would work (if I then had it plugged into a computer). The obvious problem is that where I to unplug it from the wall, USB doesn't supply enough power to use fastboot.
  2. #2
    carracerz14's Avatar
    Posts
    ROM
    Arctic HD
    Default Re: So **hypothetically**, let's say I tried to install Arctic with a low battery...
    I already told you what to do to fix it.. A simple Google search would have found you the answer :banghead:
    Here.
    Sent from my RAZR MAXXIMUS
    Thanked by:
    bradenfontaine likes this.
    I posted this half an hour (and what I thought was a different problem) before you responded.
    (look at the times). I was unaware of the significance of the charging issue as it related to my problem and believed it to be separate. Thus, one might respond to my post to fix the flashing issue, but not offer a fix for the charging issue. Ergo this posting.
  1. Trying to install CM7 with ZVJ - possible?
    By incarceration in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 04-10-2012, 09:01 PM
  2. Trying to install Launcher Pro
    By Iceman0803 in forum Android Applications
    Last Post: 09-24-2010, 06:52 AM
  3. Exclamation Point when trying to install OTA
    By mrdavis55 in forum HTC EVO 4G
    Last Post: 09-23-2010, 01:55 PM
  4. Trying to install 2.2, need help with this 'su' file.
    By mosarmini in forum Motorola Droid X
    Last Post: 08-21-2010, 01:34 AM
  5. Installation Error when Trying to Install 2.1
    By KTrentLR in forum Motorola Droid
    Last Post: 04-28-2010, 11:48 AM
