Results 1 to 7 of 7
    Default Touch Problems While Charging
    Hi,
    Has anyone else faced 'the touch screen going crazy' while charging? It mostly occurs when the charge is > 50 percent, but it's really annoying while browsing or texting,as random letters are being typed and random stuff being pressed on its own. Please share. Thanks.
  2. #2
    carracerz14's Avatar
    Posts
    ROM
    Arctic HD
    Default Re: Touch Problems While Charging
    Make sure you are using the oem charger. Third party chargers are known for this.
  3. #3
    Yeah, it has something to do with the screen sensitivity. Wish i could remember what it was.
    Sent from my DROID RAZR using Android Central Forums
  4. #4
    Bad USB cables can cause this as well.
  5. #5
    Quote Originally Posted by Mooncatt View Post
    This is most likely it. I was just using the stock Motorola charger and the screen worked perfectly. When I use an aftermarket charger that's when I noticed the screen acting funny.
  6. #6
    3rd chargers are usually the problem. My OEM works fine. Its my iGo that gives that problem once in a while.
    -Droid RAZR MAXX (Artic 2.2)
    -Motorola Xoom (Rooted/Unlocked ICS)
    -VZW 4510L LTE MiFi
  7. #7
    Ahowe125's Avatar
    Posts
    Global Posts
    110 Global Posts
    ROM
    IKream/Urban on .215 Leak
    Quote Originally Posted by dragonsamus View Post
    Good to know, I was having a similar issue with my non oem bedside charger.
    Follow me @Ahowe125 on Twitter
    | Limited Edition Razr Maxx | R3Ds PNuT.BuTTa and Urban Theme with Dual Boot on leaked JB Kernel |
  1. There was a problem while playing. Touch to retry.
    By trackath in forum HTC EVO 4G
    Last Post: 12-07-2012, 12:45 AM
  2. Touch response slllllloooooowwwww while charging
    By TauntingBull in forum Bionic Accessories
    Last Post: 11-21-2011, 03:32 PM
  3. Replies: 6
    Last Post: 06-01-2011, 11:05 AM
  4. Unresponsive Touch Screen only while charging??? (not a grounding issue)
    By musicman555 in forum Verizon Droid Incredible
    Last Post: 10-18-2010, 11:53 AM
  5. Replies: 0
    Last Post: 07-22-2010, 03:29 PM
