1. zmz723's Avatar
    Every time my phone gets down to 40%, it shoots straight down 10%, 20%, even 30%. Also happens while charging, but not as drastic.
    Pictures attached...
    Attached Thumbnails What is wrong with my phone/battery?-screenshot_2012-11-24-15-14-31.png   What is wrong with my phone/battery?-screenshot_2012-11-25-19-14-19.png
    11-26-2012 03:48 PM
  2. lynnneil's Avatar
    are you having issues with the battery life of your device?
    11-27-2012 02:40 AM
  3. zmz723's Avatar
    The only issue is that I lose 10-20% at once when it gets down to 40%, otherwise it seems to be normal.
    luoyih likes this.
    11-27-2012 10:31 AM
  4. kgk1985's Avatar
    Sounds like the battery needs calibrated. Are you rooted?
    Sent from my DROID RAZR using Android Central Forums
    11-27-2012 07:13 PM
  5. zmz723's Avatar
    I am not rooted, but have done so on previous phones so I know how to. Is there an app that can do this?
    11-28-2012 01:04 PM
  6. randylynn's Avatar
    I am having serious battery drain following the recent update (samsung gallaxy s3). I used to get a full day, and now after several hours of little use, the battery is gone. I have tried apps that clear the cache, but nothing has helped. I have not seen any replies that offer advise on this issue. I did see some things mentioned about removing the SD card with a rooted devise, but I don't know what a rooted device means, or how to do this.
    Have you resolved this issue with your phone?
    - - - Updated - - -
    12-20-2012 06:05 PM
  7. blackops1125's Avatar
    - - - Updated - - -
    This is the raze forum.
    12-24-2012 10:07 AM
  1. Can't tell if something is wrong with my phone
    By mcdaking84 in forum Verizon Galaxy Nexus
    Last Post: 12-27-2011, 12:55 PM
  2. what is wrong with my nexus??
    By chopper5273 in forum Sprint Nexus S 4G
    Last Post: 10-20-2011, 11:05 AM
  3. What is wrong with my Evo?
    By majedkassis in forum HTC EVO 4G
    Last Post: 01-07-2011, 03:27 PM
  4. What is wrong with the phone manufacturers?
    By pauldroidr2d2 in forum The Android Central Lounge
    Last Post: 09-21-2010, 07:45 AM
  5. what is wrong with my phone?
    By vertcobra99 in forum Sprint Epic 4G
    Last Post: 09-10-2010, 08:11 PM
