my droid razr powered off due to low battery charged it the motorola theme came on left it charging now nothing happens no lights come on don't have the original charger help!!!
Printable View
Sounds dead to me. When did you get the phone?
Sent from my DROID RAZR using Android Central Forums
like a month ago
- - - Updated - - -
like a month ago
I'm possibly going to get bashed for saying this in the wrong section but oh well. If you don't get it up and running I have 2 extra razr maxx 's I might be willing to sell. Pm me if your interested, otherwise I hope you fix it.
Sent from my SGH-T889 using Tapatalk 2
To start with you need the factory charger and factory cable.Quote:
Originally Posted by itsdannyyo [Only registered and activated users can see links. Click Here To Register...]
Well, that's a load of crap. I have never used the factory cable, I use my Galaxy Nexus charger for my maxx and my nexus 7. Not sure where you heard this from.Quote:
Originally Posted by MasterGadgets [Only registered and activated users can see links. Click Here To Register...]
To the OP leave it plugged in, it will take a while to turn on you won't be able to turn it on until it gets some charge.
Sent from my RAZR MAXXIMUS ;)
I charge off of 3rd party chargers everyday.Quote:
Sent from my DROID RAZR using Tapatalk 2
So if its not the charger then my phone is basically never going to turn on??
- - - Updated - - -
I suggest you go to a corporate store and have them check it out. It has a one year warranty. And it possibly is defective
Sent from my Samsung Galaxy Note2
How long has it been charging?
Also, try holding the power button and volume down for 15- 30 seconds it will force a reboot. Maybe something is just hung up.
i plugged in the charger nothing happens, I tried that already.
Because if you call Verizon Tech support or Motorola, they're going to tell you the same thing. You must use factory cable and charger. They probably know what they're talking about just a little bit more. :)
I hope that's sarcasmQuote:
Originally Posted by YoungChrisG [Only registered and activated users can see links. Click Here To Register...]
Edit: What the hell? That's not the post I quoted
To my knowledge only tablets must be used with the chargers they came with or a 3rd party charger that is for a tablet. As for phones, any cable and charger should work as long as it was from a previous smart phone or made for smart phones. Some old old micro USB from the later non smart phones do not put out enough to charge the phone.
Try plugging the phone into the computer with a different USB cable. See if it will turn on or recognize your phone. How long do you keep the phone plugged in?
DumpedDuce Approves This Message
If you call Verizon or Motorola, they're going to tell you to use the OEM charger so they can sell it to you and make money. There's no need to use the OEM charger, just make sure it has the same specs, charging capacity, etc... Don't use those cheap $4.95 eBay chargers.Quote:
Originally Posted by mydroiddoes1 [Only registered and activated users can see links. Click Here To Register...]
Regardless what "you know they are gonna say" a non OEM charger will work to charge his phone unless the charger went out completely... Try more than one charger if you haven't yet.Quote:
Originally Posted by NealJ777 [Only registered and activated users can see links. Click Here To Register...]
I've used non OEM chargers for years without any issues whatsoever. I still use a blackberry charger for my DROID phone everyday. GASP!! Sounds like either a specific charger/ cable or phone issue. Take it in and find out for sure or try a different charger and leave it plugged in for a while
Thanks to everyone for your help, i fixed the problem went threw like 4 different chargers and found one that worked.!
Good to hear man. Were all the chargers you tried USB type chargers of ones with just the wall plug mated to the wire.Quote:
yeah they were usb the one that worked had a letter B on the end of the plug connection
