Results 1 to 22 of 22
- 01-27-2013, 11:15 PM
Thread Author #1
- 01-28-2013, 12:42 AM #2
- 01-28-2013, 03:01 AM
Thread Author #3
- 01-28-2013, 05:35 AM #4
Re: Help.!! Droid razr
I'm possibly going to get bashed for saying this in the wrong section but oh well. If you don't get it up and running I have 2 extra razr maxx 's I might be willing to sell. Pm me if your interested, otherwise I hope you fix it.
Sent from my SGH-T889 using Tapatalk 2 - 01-28-2013, 10:05 AM #5
- 01-28-2013, 01:00 PM #6
Well, that's a load of crap. I have never used the factory cable, I use my Galaxy Nexus charger for my maxx and my nexus 7. Not sure where you heard this from.
To the OP leave it plugged in, it will take a while to turn on you won't be able to turn it on until it gets some charge.
Sent from my RAZR MAXXIMUS
- 01-28-2013, 01:07 PM #7
- 01-28-2013, 08:45 PM
Thread Author #8
- 01-28-2013, 08:51 PM
Thread Author #9
- 01-28-2013, 08:55 PM #10
I suggest you go to a corporate store and have them check it out. It has a one year warranty. And it possibly is defective
Sent from my Samsung Galaxy Note2
sent from either my Samsung Galaxy Note2 or my
Samsung Galaxy Tab 10.1Thanked by: - 01-28-2013, 09:37 PM #11
How long has it been charging?
- 01-28-2013, 09:38 PM #12
Also, try holding the power button and volume down for 15- 30 seconds it will force a reboot. Maybe something is just hung up.
- 01-29-2013, 01:21 AM
Thread Author #13
- 01-31-2013, 09:28 AM #14
Because if you call Verizon Tech support or Motorola, they're going to tell you the same thing. You must use factory cable and charger. They probably know what they're talking about just a little bit more.
Thanked by: - 01-31-2013, 01:23 PM #15
- 02-06-2013, 07:58 PM #16
To my knowledge only tablets must be used with the chargers they came with or a 3rd party charger that is for a tablet. As for phones, any cable and charger should work as long as it was from a previous smart phone or made for smart phones. Some old old micro USB from the later non smart phones do not put out enough to charge the phone.
Try plugging the phone into the computer with a different USB cable. See if it will turn on or recognize your phone. How long do you keep the phone plugged in?
DumpedDuce Approves This Message - 02-07-2013, 02:12 AM #17
If you call Verizon or Motorola, they're going to tell you to use the OEM charger so they can sell it to you and make money. There's no need to use the OEM charger, just make sure it has the same specs, charging capacity, etc... Don't use those cheap $4.95 eBay chargers.
Sent from my DROID RAZR using Tapatalk 2 - 02-07-2013, 05:27 AM #18
- 02-07-2013, 08:52 PM #19
I've used non OEM chargers for years without any issues whatsoever. I still use a blackberry charger for my DROID phone everyday. GASP!! Sounds like either a specific charger/ cable or phone issue. Take it in and find out for sure or try a different charger and leave it plugged in for a while
- 02-09-2013, 06:57 PM
Thread Author #20
- 02-10-2013, 06:44 AM #21
- 02-12-2013, 09:37 PM
Thread Author #22
Help.!! Droid razr
By itsdannyyo in forum Verizon Droid DNAReplies: 3Last Post: 01-28-2013, 03:49 PM -
Help with Rooting my Droid Razr 4.1.2
By Rocka210 in forum RAZR Rooting, ROMs, and HacksReplies: 4Last Post: 12-30-2012, 01:31 PM -
would like help on rooting droid razr 4.0.4
By mpierce31 in forum RAZR Rooting, ROMs, and HacksReplies: 1Last Post: 10-16-2012, 11:28 PM -
Droid Razr ICS Install Help/Notification Bar
By gvfd65 in forum Droid RAZRReplies: 5Last Post: 06-26-2012, 01:59 PM -
HELP DECIDE: Droid RAZR vs. GN vs. GS2
By Jamesla30 in forum Phone WarsReplies: 2Last Post: 01-12-2012, 12:39 PM
Reply
