1. mookiekillsit's Avatar
    OK the JB upgrade is fantastic. LOVE Google Now and can't wait to have it for an extended period of time. Only beef is my battery time is down about 40%. I used to be able to get through the day w/ moderate use and be on 40-50% when I plug it back in. Now, I'm generally at 20-10% and noticed the Android OS is the main culprit. How can I limit this?? My screen should be the culprit of taking up most battery use and Android OS and System should ideally be under 10%.
    Any ideas/suggestions would be awesome.
    Thanks!
    03-21-2013 08:54 AM
  2. jkfsr's Avatar
    I have the same problem. Hope someone comes up with a fix.
    03-21-2013 08:30 PM
  3. maxman1's Avatar
    It's been reported in the Maxx forum that going into Map settings & disabling Location Reporting makes a significant improvement.
    Sent from my Droid RAZR MAXX using Tapatalk2
    NealJ777 and Mastan Vali like this.
    03-21-2013 08:33 PM
  4. trunks527's Avatar
    Google now burns that battery.
    03-21-2013 08:56 PM
  5. blackops1125's Avatar
    http://forums.androidcentral.com/***...5&d=1364082789
    I get good battery
    Sent from my DROID RAZR using Android Central Forums
    Attached Thumbnails Battery Life After JB Upgrade-screenshot_2013-03-23-19-37-18.png
    03-23-2013 06:41 PM
  6. AlphaTango414's Avatar
    That's for the first few days or week while it is learning.
    DumpedDuce Approves This Message
    03-24-2013 11:36 AM
  7. Zorro1's Avatar
    When I thought things were getting better....not. After dropping 40% in about three hours out on 4g on Fri., it held up to 80% over 10 hours back on wifi on Sat. Sunday, started on wifi, held fine, ran out for an hour...and it literally dropped from 80% to 30%! In about an hour! What gives? Nothing wonky on the stats, and I have turned off the locator on the maps for what that's worth. And rebooted.
    03-25-2013 09:56 AM
  8. blackops1125's Avatar
    Do you have Google Now running in background? Or slacker radio, maps? Is your wifi radio on but you have no wifi to connect too(like while sleeping)? Chances are something is keeping phone from going into deepsleep, or keeps waking phone.
    03-26-2013 04:24 AM
  9. mookiekillsit's Avatar
    Thanks for the heads up. I would've thought this would show up as "Maps" in my battery usage. I may have to give it a shot. While someone suggested it may take time for Google to learn my ways, they could be right. Battery life has improved slightly and the Android OS has decreased in usage as time has gone on. This is my first experience w/ JB so I'm still a little naive.
    03-26-2013 11:51 AM
  10. NealJ777's Avatar
    Thank you. I just turned this off and we'll see what happens.
    I've been running JB since the Dec. 24 OTA "leak" and haven't had any battery issues until just this past week. I can't pin point exactly when it began, but I would say Saturday or Sunday battery started dropping fast. Normally, I charge overnight and charge again around lunch time. Yesterday, I got to work and the battery was below 40% and was BURNING UP! Actually, so hot, that the temperature warning was triggered and I turned the phone off.
    03-27-2013 01:58 AM
  11. NealJ777's Avatar
    Thank you again. It looks like we have a winner!
    I disabled Location Reporting. My phone has been off the charger for about 4 hours. The battery is 90 degrees and I have 75% left.
    Sent from my DROID RAZR using Tapatalk 2
    03-27-2013 06:04 AM
  1. Battery Stats after JB upgrade
    By flyboy28802 in forum Droid RAZR MAXX
    Last Post: 01-03-2013, 05:38 PM
  2. Poor battery life after JB update
    By Vcize in forum AT&T Galaxy S III
    Last Post: 12-26-2012, 06:49 AM
  3. Battery Life after OTA JB update
    By kdfdawg in forum Verizon Galaxy Nexus
    Last Post: 09-25-2012, 09:44 AM
  4. Poll: Lets compare the GN's battery life after the 4.0.4 upgrade
    By beck79 in forum Google / Samsung Galaxy Nexus
    Last Post: 06-14-2012, 05:03 PM
  5. Battery Life After 2.2 Update
    By caseydietz in forum HTC EVO 4G
    Last Post: 08-03-2010, 05:06 PM
