Results 1 to 12 of 12
    anon24860's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery life starting to slip?
    For those of you with Razrs at around 2 years old, are you starting to see the battery's life starting to lose its ability to keep a charge once it gets below 50%? Mine has just started to show this tendency.
    In an associated issue, who here has had their battery replaced and, if so, how much did it cost?
    TIA
  2. #2
    got root's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery life starting to slip?
    Mine was getting worse but I traded it in. I thought about trying to convert it to a MAXX with a bigger battery but gave up when the new Droids came out. good luck...
  3. #3
    Beagles329's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yup, I'm in the same boat with battery life. My Razr drops 20-30% overnight when the phone is just idle, and that is with wifi on. I'm just trying to hold on a little while longer before I upgrade.
  4. #4
    ezas's Avatar
    Posts
    Global Posts
    93 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's normal for Li-ion batteries to start losing capacity after 300 to 500 charge cycles. Which for most people would be between 1-2 yrs
    There is no way around this. Though there are best charging practices to get the most amount of life out of batteries.
    http://batteryuniversity.com/learn/a...ased_batteries
    But excess discharge while sleeping is not normal. And should be investigated with battery tools. A popular one is Better Battery Stats.
    Sent from my Nexus 7 using AC Forums mobile app
    anon24860's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yep, I knew all of that. I just figured that there might be others in the same boat. I'm actually a little early as my upgrade date isn't until Jan. As I am grandfathered in, I'm likely to keep this phone well after then. And, I lost my 5500 mH Anker battery on my recent vaca so I guess I need another one. Am leaning to their 10,000 mH big honkin' one as it's only $10 more.
  6. #6
    RecklessFable's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah, I'm at a point where I have to carry a charger wherever I go.
  7. #7
    iggyhusband's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine has recently started not to last as long anymore. With being online at work not even too much and talking on the phone for 20 minutes, it's at 10% by 4 pm.
  8. #8
    larrygeary's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The battery in my RAZR is also starting to fade. Does anyone have a link to replacement batteries and DIY instructions?
  9. #9
    lodown225's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  10. Thread Author  Thread Author    #10
    anon24860's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by lodown225 View Post
    Don't be. It's really easy. I opened the case with my fingernail (but I have long nails on my picking hand (guitar, not nose). You can use a thin bladed knife as well if you're careful. Once you get the first couple of latches popped, you can use a stiff credit card to go around the case. You might have to use the knife again when you get to the sim door. Just make sure you are gentle and just twist the knife a little. When you get most of the case loose, you can start pulling the case away from the battery, which has adhesive keeping it tight to the case. The case WILL twist easily as shown in the instructions, but be gentle. Replacing the battery is pretty easy. Just don't lose either screw or the little plastic covering. If you DO lose the cover, a tiny piece of electrical tape cut to size will work.
    Anonne likes this.
  11. #11
    larrygeary's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I followed those instructions and found it to be very easy, especially with the iFixit toolkit. I got a new battery from a seller on eBay, installed it, and the phone is as good as new, ready for another two years.
  12. Thread Author  Thread Author    #12
    anon24860's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Which battery did you end up with? Was it one of the slightly smaller ones (size-wise)?
  1. Google+ (plus) Extremely High Battery Usage
    By waynomo in forum General Help and How To
    Last Post: 04-28-2015, 05:45 AM
  2. why does it take so long for Verizon Note 2 to lock on to GPS?
    By MissyHaney in forum Verizon Galaxy Note 2
    Last Post: 08-21-2013, 09:25 AM
  3. Is there a standard way to "get to the top" of a scrolled app?
    By douglerner in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-19-2013, 02:19 PM
  4. Google Music playlists not syncing completely to my Nexus 7
    Last Post: 08-19-2013, 10:30 AM
  5. Lost all files due to encryption
    By Saddy Krish in forum Android 4.0 Ice Cream Sandwich
    Last Post: 08-19-2013, 09:49 AM
