1. bj_ben98's Avatar
    Hi guys,
    i have a motorola razr v xt885 phone. I have no idea what happened but my phone has a small crack. Everything still is working perfectly. Everything is ok just for the little crack on my screen. The touchscreen on my phone does not work however. It is not detecting the multitouch when i press the screen. ( One side of the screen works, other side doesnt).Please i need my phone for next week. Any ideas? Just remember that the phone is still normal, just the touchscreen ( You cant remove the battery on this phone) Please help guys
    Thanks
    10-25-2013 06:50 AM
  2. Golfdriver97's Avatar
    Hi guys,
    Thanks
    Welcome to the forums. Short of replacing the screen, there really is no fix. Do you have insurance?
    10-25-2013 09:32 AM
  3. bj_ben98's Avatar
    I bought this phone online on catch of the day like the beginning of the year. I think it was 1 month warrantee and im over already. DO you think i can just changed or repair the screen of my phones from one of those repair store or from one of those asian mini phone stores?
    10-25-2013 10:31 AM
  4. Golfdriver97's Avatar
    It may be worth a try.
    From a Sprint Moto X using AC forums app
    10-25-2013 11:12 AM
  5. bj_ben98's Avatar
    Ill think ill go try to change or replace the screen today, how huch does it useually cost?
    10-25-2013 07:51 PM
  6. Golfdriver97's Avatar
    Unfortunately I have no idea. That sort of thing has not happened yet.
    10-25-2013 08:49 PM
  7. bj_ben98's Avatar
    thnx alot! i went to get a repair from an asian store and tey fised it all and made my phone even better than before in 1 hour.
    10-27-2013 07:05 AM
  8. Golfdriver97's Avatar
    Glad to hear it. See you around the forums.
    10-27-2013 08:04 AM
  1. Can I Do this on my Galaxy s4?
    By ManvirS in forum Samsung Galaxy S4
    Last Post: 10-28-2013, 11:21 PM
  2. What happened to all my apps??????????????????????????????
    By Moltres_rider in forum Droid RAZR
    Last Post: 10-25-2013, 02:43 PM
  3. Scan NFC Tag while phone is asleep
    By ccpopham in forum Verizon Samsung Galaxy Note 3
    Last Post: 10-25-2013, 09:35 AM
  4. HELP! Samsung N7000 blocked out after attempting to update to 4.2.2
    By DrChinkeechopstxs in forum Samsung Galaxy Note
    Last Post: 10-25-2013, 06:02 AM
  5. I cannot switch on and HARD RESET my HTC ONE S!!!
    By Zeeshan Jamal in forum HTC One M7
    Last Post: 10-25-2013, 03:23 AM
