Results 1 to 3 of 3
    braxster1992's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default I need help rooting my Droid Razr
    Ok so I have been trying to do this for the past day. I have a droid razor xt912 and I am trying to root it. I am doing it on a mac and this is what I get.
    * One-Click Root Script for Droid Razr
    * brought to you by DroidRazrRoot.com
    * Credit goes to XDA user djrbliss Dan Rosenburg for exploit.
    This script will give you
    1. Root and SuperUser
    2. Install Busybox
    Before you begin:
    Please read full tutorial at DroidRazrRoot.com!
    waiting... If you get stuck here, try another USB port.
    Start Rooting...
    reboot #1 - DO NOT DISCONNECT YOUR DEVICE!
    rm failed for /data/local.prop, No such file or directory
    /system/bin/sh: can't create /data/local.prop: Permission denied
    reboot #2 - DO NOT DISCONNECT YOUR DEVICE!
    remount failed: Operation not permitted
    failed to copy 'su' to '/system/bin/su': Read-only file system
    Unable to chown /system/bin/su: No such file or directory
    Unable to chmod /system/bin/su: No such file or directory
    rm failed for /system/xbin/su, No such file or directory
    link failed Read-only file system
    failed to copy 'Superuser.apk' to '/system/app/./Superuser.apk': Read-only file system
    rm failed for /data/local/tmp, Permission denied
    failed on '/data/local/tmp.bak' - No such file or directory
    3889 KB/s (1075144 bytes in 0.269s)
    mount: permission denied (are you root?)
    /system/xbin/busybox: cannot open for write: Read-only file system
    Unable to chown /system/xbin/busybox: No such file or directory
    Unable to chmod /system/xbin/busybox: No such file or directory
    /system/bin/sh: /system/xbin/busybox: not found
    rebooting
    All Done rooting Droid Razr, subscribe to DroidRazrRoot.com for more cool stuff like ROMs, hacks, tips, and more!
    RootMac.sh: line 52: @pause: command not found
    After that I go and check my phone to see if it worked and it didn't. I need help badly as to I am new to android and rooting.
  2. Thread Author  Thread Author    #2
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: I need help rooting my Droid Razr
    O and If your wondering my droid razr is running android 4.1.2
  3. #3
    SoccerRef12's Avatar
    Posts
    Global Posts
    1,240 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Find a PC and use Matt's utility on the XDA website.
    http://forum.xda-developers.com/show....php?t=2192467
  1. Replies: 5
    Last Post: 06-29-2014, 07:40 PM
  2. Need help with Symbol key
    By inc55 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-27-2014, 03:15 AM
  3. Verizon Note 3 On Tmobile SLIGHT Issue Need Help Please
    By airgreek in forum Verizon Samsung Galaxy Note 3
    Last Post: 02-23-2014, 01:52 PM
  4. Where is my movie ?
    By losl in forum Google Nexus 5
    Last Post: 02-22-2014, 06:25 PM
  5. Android Tablet with 4.2.2 SD card problem. Please help!
    By md363 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-22-2014, 02:14 PM
