Results 1 to 3 of 3
    Default The way to replace battery of XT910
    Hi,Guys!
    I got my XT910 for more than 1 year.I do love this phone,but after more than one year's use,it can only last for several hours.Sometimes I even want to throw it due to the non-removable battery.After my careful study and search,I finally find the way to replace the battery of my XT910.Now, I wanna share it with you.
    Tools:T5 Hexagonal Screwdriver,Tweezers,Tapes, replacement battery EB20(I got the battery from Onite on Amazon)
    Steps:
    Step 1:Open the back cover(This step is easy but be careful not to pull too hard).
    Step 2:Use T5 screwdriver to twist two screws that on the flat cable, then use tweezers to pick the flat cable gently (be careful not to lost the insulation gasket below).
    Step 3:Take out the original battery gently,then put the battery you bought.
    Step 4:Put the insulation gasket back that you took from the original battery,and put the screws back .(be careful do not overexert to damage the flat cable port)
    Step 5:Attach the double faced adhesive tape to the back for the battery,stick it with phone and compress it.
    Step 6:Put the cover back.
    Step 7:Power on the phone.Finished.
    I have attached some pictures of it,that would help.Good luck!
    Attached Thumbnails Attached Thumbnails The way to replace battery of XT910-1.jpg   The way to replace battery of XT910-2.jpg   The way to replace battery of XT910-3.jpg   The way to replace battery of XT910-4.jpg   The way to replace battery of XT910-5.jpg
    The way to replace battery of XT910-6.jpg   The way to replace battery of XT910-7.jpg   The way to replace battery of XT910-8.jpg   The way to replace battery of XT910-9.jpg   The way to replace battery of XT910-10.jpg
    B. Diddy likes this.
  2. #2
    Default Re: The way to replace battery of XT910
    Very helpful, thanks!
    You should be careful enough in step 2 and step 4.
  1. How to set network mode in Korean Samsung note 2 - Model no. SHV-E250L ?
    By AC Question in forum Samsung Galaxy Note 2
    Last Post: 11-10-2016, 12:42 AM
  2. How to send Notifications in android
    By Munawwar in forum Software Development and Hacking
    Last Post: 08-24-2014, 10:51 PM
  3. YOWCH.......my SD card is all of the sudden BLANK!!!
    By sanzfrancisco in forum Ask a Question
    Last Post: 07-09-2014, 08:27 PM
  4. Replies: 6
    Last Post: 07-09-2014, 01:17 PM
  5. Galaxy S4 drains battery while plugged in and charging
    Last Post: 06-25-2014, 03:39 AM
