08-04-2010 06:50 PM
33 12
tools
  1. Smoke N Crack's Avatar
    Verizon has like 4 different cases for the X . what is everyone using?
    07-15-2010 11:11 AM
  2. vicw926a4's Avatar
    I ordered a shell/holster combo from Verizon. I plan to get a charging station, and the rep recommended it as a relatively easy removal for switching to the station. Seems like it will provide some protection, and has a reasonably tactile, but not sticky feel. Should arrive tomorrow.
    07-15-2010 11:19 AM
  3. DroidNewb's Avatar
    I have silicone now and a leather wrap snap on with built in kickstand coming....there is a sticky thread above that discusses cases fyi...
    07-15-2010 11:37 AM
  4. stormaddict13's Avatar
    I got the black carbon fiber one and it's pretty nice. Don't know how much I'll actually use it but when I need to it will do the job.
    07-15-2010 11:38 AM
  5. zachflauaus's Avatar
    I got the shell/holster combo as well and I love it. It's similar to the Casemate Barely There case which is what I had with my BlackBerry and it is good to use. I don't use the holster but the shell has a good grip and texture to it. Unfortunately I can't get it into the desktop charger but I haven't tried very hard.
    07-15-2010 12:25 PM
  6. bc6droid's Avatar
    As with the Incredible I got the VZW Shell/Holster combo setup.
    07-15-2010 01:21 PM
  7. scramblerider5's Avatar
    I got the carbon fiber case with overnight shipping
    07-15-2010 02:49 PM
  8. Bond32's Avatar
    Personally I went with the hip holster and anti glare protectors. Very impressed with the holster - it has a professional look to it, and it allows good protection while still allowing docking. The screen protectors I am not so impressed with, as they are not fitted for the entire screen but just where the business is.
    07-15-2010 05:38 PM
  9. Tsunami T2's Avatar
    got the screen protector and silicone cover. cover makes the phone feel clunky. might take it back.
    07-15-2010 08:17 PM
  10. otkeeper's Avatar
    i just ordered the verizon black silicone case to hold me over till my invisible shield and or better options from the other 3rd party makers.
    07-16-2010 11:08 AM
  11. BWD's Avatar
    While I was in the store I got the screen protectors (had them install one) and got the Carbon Fiber Snap-On Hard Case. I like it!
    07-16-2010 11:29 AM
  12. peargirl's Avatar
    I bought Verizon's silicone case in purple.
    I really want a case-mate Gelli case and may still get one if they ever come out. I had one for my tour and loved it.
    I do like the case I have though.
    07-16-2010 12:29 PM
  13. Vone's Avatar
    Anyone try the case with kickstand? how is that one?
    07-16-2010 02:01 PM
  14. mnasholm's Avatar
    I just got the Case + Holister....AMAZING!!!!!!!!!
    07-16-2010 03:22 PM
  15. Adiliyo's Avatar
    i'm not a fan of cases, but when i was at the vzw store picking up the phone yesterday they had a carbon fiber snap on case that was pretty tempting.
    but i like my thin phones to stay thin...
    07-16-2010 03:30 PM
  16. focus791's Avatar
    Only think I don't like about the shell is that it has no top portion covering the corners. That makes me a little worried in the event of a fall...I may switch to the Seidio case when it comes out. The Seidios are also easier to get out of the holster.
    07-16-2010 08:38 PM
  17. Bond32's Avatar
    Leather holster is still the way to go! Especially if you get either of the docks.
    07-16-2010 09:02 PM
  18. mountainman's Avatar
    I
    The body glove case with the clip doubles as a decent kickstand.
    Not a bad case at all, but i still want an otterbox.
    And PLEASE - someone make a case that will fit an extended battery when it comes out.
    07-17-2010 01:39 AM
  19. JDHunz's Avatar
    I bought both the silicone and carbon fiber cases - have been using the silicone one - the two-piece is just too bulky, so I think I will return it and get the holster.
    For those wondering, using either the VZW car or home dock requires you to remove any of the VZW cases. That said, the silicone case is a very easy on/easy off case, so I haven't been bothered with taking it off for either dock.
    Personally, I like the silicone case - it doesn't really add much to the size of the phone and, like a previous poster, doesn't snag in your pocket.
    Hope that helps some...
    07-17-2010 07:57 AM
  20. memphisboy's Avatar
    Looking past the Bulkiness, The BodyGlove does wonders for my X....I just love the feel and sense of a softer impact in the event I am to drop my phone....
    07-17-2010 09:11 AM
  21. derpudel's Avatar
    I purchased the silicone case today. My X doesn't arrive until Monday, so I'll update after I've used it for further remarks.
    07-17-2010 12:02 PM
  22. milo12's Avatar
    I like the silicone case but I hate the way it covers the buttons. It makes them virtually invisible and blocks the light. I will trim it away with a razor and see if that helps.
    07-17-2010 03:29 PM
  23. jedge's Avatar
    Same here, the holster is perfect if you use docks and/or just don't like ugly/bulky/silicony cases. The verizon one available at launch is top-quality.
    2 things though:
    1) it's not quite tight enough... leather relaxes over time and while the magnetic snap means there's NO chance it could ever fall out, when you are removing it single-handed i like there to be a bit more friction so it doesn't "pop" out.
    2) the elastic-leather blocks the earphone jack. actually, it just barely covers the jack so if you push you can get your earphones in... but still seems like a design flaw.
    07-17-2010 10:55 PM
  24. azekiss's Avatar
    I have the bodyglove snap on, I had it on my blackberry and loved it. I makes the phone easier for me to hold and is is non skid.
    07-18-2010 02:03 PM
  25. azekiss's Avatar
    They have several to choose from at big red.
    07-18-2010 02:06 PM
33 12
