1. Brain1993's Avatar
    I can't get files to save directly to the external. The internal virtual is there but it won't send to the external only with a rooted file explorer can I move schizophrenia. The SD card is recognized but idle why it isn't saving to it
    Sent from my LS670 using Android Central Forums
    07-08-2012 09:47 PM
