Results 1 to 2 of 2
- 05-07-2012, 08:43 AM
Thread Author #1
Replacement battery cover for 3300 Seidio Extended Battery?
I bought a 3300 Seidio extended battery when they were announced a while back and the back cover that comes with it is very poorly made. It didn't help that I dropped my phone a few times either.... Now the cover barely stays on. I'd like to get a new cover, but preferably not a Seidio one. I e-mailed about getting a replacement, and they said it would cost me $14.99. That seems a bit excessive for a poorly made back cover. Does anyone have a suggestion for another cover that will fit over the 3300 Seidio battery? Thanks!
- 07-01-2012, 10:58 PM #2
Re: Replacement battery cover for 3300 Seidio Extended Battery?
I had 2 replaced under warranty .(covers) AND i ORDER one cause I"m out of warranty and it was worst then the one I had. 14.99 the shipping all in all it was 21.00. I sent it back for a refund I figure for 21 dollar I can order 3 set of extend battery off flea bay. They will work good for about 3-4 month each by then it'll be time for a upgrade. But I will never do seidio again,
Reply
