Results 1 to 17 of 17
- 06-14-2011, 02:05 AM
Thread Author #1
- 06-14-2011, 05:28 PM #2
- 06-28-2011, 08:00 PM #3
Re: Epic 4G 1700 mAh Battery
Does 2800 battery need an extended door, or will the stock back fit with it.
- 06-29-2011, 09:40 AM #4
- 07-04-2011, 01:01 PM #5
- 07-21-2011, 12:12 AM #6
- 07-22-2011, 01:26 PM #7
In my experience, the true oem stock battery is the best.
I have had standard batteries in both std mah and extended mah from cheap China batteries, Sedio batteries, oem fake labled batteries, and although with the exception of extended batteries, the true oem stock battery lasted the longest and had the best long life (i.e, many charging cycles) also.Samsung Galaxy S3 (tweaked, but stock)
Samsung Epic 4G (retired rooted backup)
Samsung Galaxy Tab 7.0 Plus
Samsung Galaxy Note 10.1
Apple iPad 3 (yes, I have one of those also)
Lexar 32gb Class 10
Samsung 32gb Class 10
SanDisk 64gb UH1 Class 10
kickstand4u tm
Rock Solid and Perfect!
Take a kickstand4u poll over at XDA
If I have helped you - click on the Thanks Button! - 07-22-2011, 10:13 PM #8
So where is the cheapest place to find a stock battery? Sprint wants $50.
- 07-27-2011, 10:59 AM #9
On Amazon you can get the Samsung external battery charger which also comes with a battery for around $30. When I got it a while back it was $20 or $25... must've been on sale.
Amazon.com: OEM Samsung Standard Battery w/ External Battery Charger & Stand for Samsung Captivate Vibrant Epic 4G Focus: Cell Phones & Accessories - 08-20-2011, 07:24 PM
Thread Author #10
- 09-02-2011, 05:21 PM #11
If anyone is looking for a pretty good deal for a great Extended battery that comes with the back cover I can definitely vouch for Gorilla Gadgets 3500mAh one. For $25 with the cover I think its a great deal. I've had it for almost 2 weeks now and its definitely not just some cheap battery. They have great customer service and quick shipping. I also bought their belt clip holster ($10) which I prefer over other phone cases/holder because they put the face towards your body and not facing out so the screen gets nicked up. Here is a link to the battery if anyone is interested. Also, I found out that the belt clip holster also fits the standard battery and cover snug. I actually like this cover over Seidio which is my normal route but I would have paid over $100 for the battery, cover and holster. Gorilla Gadgets doesn't have a picture of the holster but if you go to Seidio's website its the same style as the one you get when you buy one of their hard cover cases and you have to get the combo set for the phone to fit. I put a link to Seidio's belt clip holster so you can see what the Gorilla one would look like. There is one difference that I actually like better on the Gorilla one. (I had the combo from Seidio for my Samsung Instinct and it was great). The clip part that goes to your belt has a "U" shape at the bottom so it actually snags onto your belt so it doesn't slip off which I actually find a great design. Seidio's just had a little lip on it but still a great clip.
Now, I just have to find a great cradle and 2nd batter charger set up. Might have to go back to Seidio. I was hoping to find a side mounting cradle so I can watch/surf in landscape mode while its charging. I have the extended battery so I doubt it would plug in correctly to one made for the stock set up unless it was corded like the one Gorilla Gadgets has. The one they have is not landscape though which is why I am not going with theirs. Here is are links to what I purchased already and the charger set up I'm thinking of getting from Seidio. Any experience with the charger, let me know. Thanks in advance.
Jim
Batter/Cover:
What Gorilla Gadgets Belt Clip Holster looks like:
Belt Clip Holster:
Multi Function Charger: - 10-06-2011, 12:57 PM #12
- 10-07-2011, 11:23 AM #13
The OEM battery for the epic 4g touch work in the epic 4g. They are 1800mh
Sprint Smartphones: HTC Touch to HTC Diamond to Palm Pre to HTC EVO 4g (returned within 30 days) to Samsung Epic 4g to Epic 4g Touch to Galaxy Note 2. - 10-07-2011, 12:57 PM #14Thanked by:
- 10-15-2011, 11:04 AM #15
Just got 2 Anker 1800 mAh batteries and charger for my Epic 4g Touch. Ordered on 13th, got it today. 2 days from California, fantastic service!
The charger is very cool. I have the charger plugged into the Epic power cord, have one of the new batteries charging and then have a micro USB cord to my Epic and that is charging at same time. The charger also works on other batteries too. The battery fits perfectly, its exactly the same size as stock battery.
$19.99 including shipping, got it from Amazon from LaptopMate. Great seller.
Now will charge and replace by Epic battery and see how long they last.
Treo's going back to dark ages, Pre Minus, Motorola Photon, Galaxy S2 and now Galaxy S4 & Asus T700 TabletThanked by: - 11-25-2011, 11:22 PM #16
- 04-20-2013, 09:20 AM #17
Reply
