Tested on EF02 with cwm 3.1.0.1
First flash the zip... it gives you about 8 seconds to lay the phone on a flat surface after hitting yes to flash the zip...
then some framework edits will need to be made....
needs to be changed to
if you have a framework.jar that has been modified, make the edits, if you are stock there is a stock deodexed framework.jar edited..
EF02 Rotation Lag Fix
\system\framework\framework1.jar.out\smali\android\view\WindowOrientationListener.smali
Code:
.prologue
.line 54
const/4 v0, 0x3
Code:
.prologue
.line 54
const/4 v0, 0x2
