Page 1 of 2 12 LastLast
Results 1 to 25 of 48
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Milestone 1/Lean Kernel
    Default [INDEX][EG22] Gingerbread EG22 Leak ROMs/Themes/Misc.
    GINGERBREAD " Leak" EG22
    (Note: Battery Meter/Mod is not stock)
    In usual tradition I will try my best to keep up with this thread. It will have whatever available ROMs/Odin Packages/Themes/Misc. stuff pertaining to Gingerbread EG22 leak.
    All links provided here lead to the main threads and I nor Android Central claim no credit to any of these unless it is something I did. Thanks again to all our great devs and users in the Epic community.
    ROM/Odin: (Stock download from Samfirmware.com thread)
    Credit: theduce102
    ROM/Odin:
    Credit: crawrj
    ROM/CWM:
    Credit: Decad3nce
    ROM/Odin:
    Credit: crawrj
    Theme/Mod: [MOD][THEME][EG22][GINGERBREAD] Stock Theme with Battery Mod
    Credit: Paul627g
    Theme/Mod:
    Credit: Tortel1210
    Kernel:
    Credit: chris41g
    Theme/Mod:
    Credit: Tortel1210
    Theme/Mod: (Updated to support EG22)
    Credit: mad doggin
    Theme/Mod:
    Credit: qbking77/ACS
    Credit: mad doggin
    ROM/CWM: (EXT4 !)
    Credit: lviv73
    ROM/CWM:
    Credit: RandomKing
    ROM:
    Credit: ERA
    ROM/CWM:
    Credit: ACS/Jez2cool
    MOD/CWM:
    Credit: crawrj
  2. #2
    Default Re: [INDEX][EG22] Gingerbread EG22 Leak ROMs/Themes/Misc.
    Thanks for this.
    EDIT:
    Installed, flashed the new modem.bin, restored from CWM backup, so far it's working beautifully. I haven't noticed any practical performance boost yet, but the numbers from Linpack, Quadrant and Neocore are pretty decent.
    Linpack: 14.5Mflops (EDIT: subsequent runs show 16.5+ Mflops)
    Quadrant: 1496
    Neocore: 54 fps
    This is a slight boost from EF02 with the EF10 modem, though I forget what the stats there said. To note, I am NOT on ext4, but my data card is a class 10 SDHC 32GB. I don't know how much that affects performance, but it sure affects file transfers over USB. I flashed the deodexed ROM with CWM 3.1.0.1 purple and the modem.bin with Odin. I haven't had a chance to test GPS yet; the GPS driver kept locking up on EF02 and I had to hard-reset the phone to bring it back. Hopefully that won't be an issue here.
    I am not an atomic playboy. - Admiral W.P. Blandy
    Thanked by:
    Rdjinc
  3. #3
    Officerpolabear's Avatar
    Posts
    Global Posts
    902 Global Posts
    ROM
    AOKP JB
    Does anyone know if the CRT animation for EF02 can be flashed for EG22?
  4. #4
    Quote Originally Posted by Officerpolabear View Post
    It can't, unfortunately. You'll just have to wait. =\
  5. #5
    Posts
    Global Posts
    902 Global Posts
    ROM
    AOKP JB
    Quote Originally Posted by acer1096xxx View Post
    Well, my waiting is over haha
  6. #6
    Can you explain the differences in the links? (What each does or doesn't do).. thanks,
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Quote Originally Posted by Big Kahuna View Post
    If you click on the links they will send you to the OP for each thread.
    Basically you have 4 actual ROM links up there and the others are mods and a kernel.
    The ROMs are offered using either Odin or CWM to flash the leaked ROM. Then you have your choice of getting it in either deodexed or odexed versions.
    Any further questions just ask.
  8. #8
    tomy2001's Avatar
    Posts
    ROM
    EH17 U. Metamorphosis 2.0
    I have been running this leak(EG22) since it came out. I do not have any complian. I have not found any issue.
    The EE03 is a good leak but is not stable. The modem on EG22 does not crash at all. This was the main issue I found on EE03, EF02, Ef10. I believe Sprint has a winner!!!
  9. #9
    Posts
    Global Posts
    902 Global Posts
    ROM
    AOKP JB
    How do I convert my Filesystem to EXT4 with the kernel? I already have the kernel flashed.
  10. #10
    From what I can tell, google nav doesn't get a solid lock and sometimes loses signal. Anybody else getting the same?
  11. Thread Author  Thread Author    #11
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Can't... Its only "EXT4 compliant" but nobody has created a ROM yet to make it EXT4.
    Thanked by:
  12. #12
    mike340t's Avatar
    Posts
    Global Posts
    770 Global Posts
    ROM
    Rooted Stock
    Also the updated wireless hotspot for this leak works awesome! 4G tether is working!! Not sure if it's ok to post link or not, but I thought I'll mention it works great...
    My history: Ericsson 628, 768, T10, T28 World, Siemens S12, Nokia 8290, 3390, Motorola C330 , V70, Ericsson T68i, Motorola v100, Accompli 009, Sony Ericsson P800, T300, T610, O2 XDA II, BlackBerry 6210, Sanyo SCP5300, SCP8100, VM4500, PM8200, MM7400, MM8300, MM9000, BlackBerry 7750, Kyocera KX18, MM-A900, SCP8400, Pearl 8130, Tour 9630, Samsung Epic 4G, HTC Design 4G, Nook Tablet. CO's: Omnipoint, Voicestream, T-Mobile, (Amp'd for a short time) Sprint, Verizon
  13. #13
    deligator's Avatar
    Posts
    ROM
    EG22 DeODEXed stock-ish
    Are there any OC / UV kernels that are compatible with EG22 yet?
  14. Thread Author  Thread Author    #14
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Quote Originally Posted by deligator View Post
    No source code/official release=no oc/uv kernels.
    Thanked by:
  15. #15
    curtis33's Avatar
    Posts
    ROM
    Stock Root
    I have noticed a significant speed increase. There is very little lag and operation seems much smoother. My phone has turned off for no reason and google nav does not lock on easily.
  16. #16
    curtis33's Avatar
    Posts
    ROM
    Stock Root
    Quote Originally Posted by bigtymer7680 View Post
    from what i can tell, google nav doesn't get a solid lock and sometimes loses signal. Anybody else getting the same?
    i have the same issue. Telnav seems to work fine
    Thanked by:
  17. Thread Author  Thread Author    #17
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    The little issues everyone is having here and there seem to be so minor at this point. Everyone needs to remember this is still a leaked build. So it does still have some debugging code left in it which slows things down and causes conflicts. Plus the final version once packaged usually cleans up the last of the little bugs, but I think Sammy has really done a great job on this latest leak. Whatever little remaining bugs like rotation lag or keyboard lag will be cleaned up almost instantly once the kernel devs get their hands on the official source code.
    I actually can't wait to flash back to it and get off EC05, but I end up going back due to my themes and other things requiring EC05.
  18. #18
    sylvio13's Avatar
    Posts
    Global Posts
    25 Global Posts
    ROM
    Baked Snack 1.6 / Step-2
    Everything seems pretty nice except scrolling in the browser is choppy. Might just be an isolated issue for me though. Battery is ok for a stock rom.
  19. Thread Author  Thread Author    #19
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Choppy browser scrolling is one of the bugs being mentioned. A fair share of users install a different browser anyways so it hasn't been a very big issue but its still a valid complaint.
  20. #20
    Giblet's Avatar
    Posts
    Global Posts
    167 Global Posts
    It is not possible to turn off the shutter sound in this version. I'll have to see if I can locate the file and change it to a blank audio file
  21. #21
    Instructions on how to put this root on my epic
    [Odin]Stock EG22 Deodexed with CWM 3.1.0.1/Root/Busybox 1.18.4
    is this a good root and what does it give me????
  22. Thread Author  Thread Author    #22
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Quote Originally Posted by greenfairy4206 View Post
    This is the latest Gingerbread leak build we have to play with. It is very stable, has very little bugs in it. We are expecting probably one more leaked build possibly before official comes out later this month as rumored.
    It will give you a stock Gingerbread OS, rooted (Superuser access) and CWM (ClockworkMod) installed. You will be able to do as you please, flash themes, remove bloatware, etc.
  23. #23
    Do I flash my phone using odin
  24. Thread Author  Thread Author    #24
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Yes follow the instructions, the one you mentioned above uses Odin to flash it. Its an all in one package, it will install Gingerbread & root your device all in one package.
    Notice it says "Odin" in the beginning meaning this uses/requires Odin to flash.
  25. #25
    tomy2001's Avatar
    Posts
    ROM
    @Greenfairy4206
    Are you new rooting your phone? Or new with android? That is ok. if you need help only ask.
    By the way, I love Gingerbread EG22 leak. It is very stable.
