1. steveokinevo's Avatar
    so to make a long story short i need a ROM that works with metro pcs service (MMS, web). my phone was working fine at 1 point. had to unbrick it. then install a stock ROM EL30 (i believe). then flashed to a rooted FC09. now im on cyanogen mod 9 and my calls work but no data or MMS. any help is very much appreciated!!!
    04-16-2012 06:01 PM
  2. ratsttam's Avatar
    Any rooted rom will work (actually, stock unrooted may too if you know your MSL code), you need to follow directions for flashing patches, or entering service information into the service menus. Do a brief search around here, and you'll find what you're looking for.
    04-17-2012 07:30 AM
  3. steveokinevo's Avatar
    Thx for the info. I've been looking around for a few days now and no luck...... now I'm running gingerbread fc09 2.3.6 (since it seems to be working the best) and everything seems to work but mms.
    04-17-2012 09:33 AM
