1. icewater106's Avatar
    I tried two computers and watched qbking video and when I click start is says < OSM> All threads completed succeed 0/ failed 1) I have the epic 4g
    Attached Thumbnails Need help Odin will not unroot.-uploadfromtaptalk1349396721502.jpg
    10-04-2012 07:25 PM
  2. Paul627g's Avatar
    Okay from looking at your screenshot two possibilities...
    1. Uncheck the repartion box... That shouldn't be necessary unless you were running a custom ROM that was using the MTD format.
    2. Your tar file in the PDA slot.. I noticed the extension on it was SPH-D700-FC09-8Gb-REL.tar.md5.zip, using a file explorer like Windows Explorer name the file so you loose the ".zip" extension and give that a go..... Make sure you have it set to show extensions in your file explorer so you can change/rename it.
    I think the ".zip" is what is causing it to fail.
    Report back and good luck.
    10-04-2012 07:30 PM
  3. icewater106's Avatar
    That worked it went through thanks now it just says set partition
    Attached Thumbnails Need help Odin will not unroot.-uploadfromtaptalk1349397640686.jpg
    10-04-2012 07:42 PM
  4. icewater106's Avatar
    I'm using cm9 and when I rooted the phone I used a mtd file
    10-04-2012 07:43 PM
  5. Paul627g's Avatar
    Try running it again without the repartition selected.. Use the pit file just don't check the repartition box...
    If it flashes and goes thru you should be okay.
    10-04-2012 07:45 PM
  6. icewater106's Avatar
    It says fail in the first white box. It also says can't open the serial (COM) port
    Attached Thumbnails Need help Odin will not unroot.-uploadfromtaptalk1349398307988.jpg
    10-04-2012 07:52 PM
  7. Paul627g's Avatar
    Not what I wanted to see.. Try using the repartition box again and see if it will go thru... Darn MTD ! This is where I stepped off my Epic 4g when they started with the MTD.. While it was a great thing I also saw problems from time to time when unrooting/restore to stock with this partitioning of the file system from MTD back to stock RFS....
    10-04-2012 07:58 PM
  8. icewater106's Avatar
    Its going through I used my other computer. Thanks a lot it passed my phone is unrooted now.
    Google should hire u
    10-04-2012 07:59 PM
  9. Paul627g's Avatar
    Awesome.. What worked? Repartiton checked or unchecked?
    10-04-2012 08:02 PM
  10. icewater106's Avatar
    Repartition unchecked
    Paul627g likes this.
    10-04-2012 08:03 PM
  11. Paul627g's Avatar
    Awesome... Will have to keep this in mind for future, I will amend my Restore to Factory Stock instructions for others following in your footsteps.
    10-04-2012 08:06 PM
  1. Please help: Evo will not boot -just vibrates
    By kikaperez1 in forum HTC EVO 4G
    Last Post: 07-31-2011, 05:38 PM
  2. Please I need help, I can not download anything?
    By v2playa in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 04-22-2011, 10:20 AM
  3. Please Help: Phone will not charge!
    By ccannon917 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 03-02-2011, 07:13 PM
  4. Help!! Recovery will not flash
    By RG1#AC in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 11-18-2010, 12:06 PM
  5. Need help with signature(not gmail)
    By epicdemon in forum General Help and How To
    Last Post: 11-08-2010, 07:09 PM
