Results 1 to 15 of 15
- 12-19-2010, 08:03 PM
Thread Author #1
Stuck in System Recovery <2e> manual mode
I was trying to fix my gps on 2.2 and flashed back to 2.1 than got the gps lock and flashed back to a saved rom by recovery.
now i'm stuck on a "Android system recovery <2e> Manual mode. It a screen with blue words and a pic of an exclamation piont. I try to apply update.zip but it says E:cant mount dev/block/vold/179:1
No such file of directory
E: cant mount SDCARD:update.zip
I can use odin because my computer wont recognize my phone. i downloaded the drivers over and over, used 2 different computers, and used 2 different USB cords.
HELP - 12-19-2010, 08:46 PM #2
- 12-19-2010, 09:18 PM
Thread Author #3
ok i had to jack with my phone alot. putting it in and out of download mode and pulling the usb in and out, but i finally got it to reconize my phone after a few hours. what a pain!!!
- 12-20-2010, 02:14 PM
Thread Author #4
tired to do it all again today at work and same thing happened. luckily my work computer recognizes my phone better than both my home computers.
WTH is up with restoring my backups from clockwork. why do i keep getting stuck with the blue screen of death? I cleared the memory and everything. - 12-20-2010, 04:45 PM #5
Try restoring your backup and then flashing the ROM on top of that.
- 02-10-2011, 04:46 PM #6
- 02-10-2011, 06:01 PM #7
If you can't boot up, you can always use Odin to flash back to stock.
- 02-10-2011, 07:02 PM #8
"In Soviet Russia, Android roots you!"
I'm here because like you, I have questions that I need answered, and help those like me, with questions of their own.
"If I have seen further it is by standing on the shoulders of giants."
-Isaac Newton, Letter to Robert Hooke, February 5, 1675Thanked by: - 02-11-2011, 06:36 AM #9
- 02-13-2011, 10:23 PM #10
when i first rooted my phone on 2.1, i got stuck on the stock recovery every time i booted to recover.y.
i actually had to hit apply update.zip from sd card to get into clockwork mod recovery.
anyways, i think the op forgot that you cant just flash back and forth between 2.1 and 2.2 roms. his post to me sounds like he was on 2.2 went to 2.1 and 2.2 again; which i dont think is possible because you need the kernel for 2.2 and stuff
i could be wrong cuz my android hacking is getting kinda rustyEPIC 4G
ROM: QUANTUM 2.O
KERNEL: STOCK
- 02-14-2011, 01:45 AM #11
Your correct you can't simply flash back and forth between 2.1 (Eclair) and 2.2 (Froyo) ROMs. You have to use Odin to return to Eclair from Froyo, then you have to use either Odin or an update.zip file to go from Eclair to Froyo. There is no simple "flashing" between OS's versions. Flashing can only be done on when staying on the same OS (Eclair or Froyo).
:: Getting Started with Android :: Forum Rules :: General Help and How To ::
» » » The All New Android Central App « « «
- 04-12-2011, 05:51 PM #12
- 04-12-2011, 06:16 PM #13
- 04-12-2011, 06:25 PM #14
- 09-21-2012, 12:24 PM #15
Reply
