1. DubzEm's Avatar
    So I rooted my phone and have tried a few diffrent roms and for some reason on every one of them my gps will not work. It just says searching for location and it will never find me. Can any one help me??? I use my gps all the time and i dont want to flash my phone back to stock.
    02-08-2011 10:43 AM
  2. a_c_s's Avatar
    There are a number of fixes for GPS issues if you look in the sticky section of the ROM forum... these seem to help most people... the other option is to flash back to stock with Odin, get a lock, then start over with a reroot and reflash. If this still does not fix the issue, try a hardware swap... my original Epic had occasional GPS issues as well... my current one works perfectly with every single custom ROM that does not have rom-specific GPS issues... good luck...
    02-08-2011 11:40 AM
  3. Paul627g's Avatar
    Four Ways to Fix GPS Problems in Froyo
    02-08-2011 12:16 PM
  4. nmoreman's Avatar
    I am so amazed at your patient responses after someone has to page right by the GPS sticky to post that question.
    02-09-2011 05:10 AM
