So I'm trying to do my first root using baked snack 2.1 and I've run into the first issue.
I have a Stock Epic 4g with EB13 which was installed about a month ago via OTA push.
I have to PCs that I've tried the below process with and I've had identical results. The first PC is Win7 Pro x64 and the second PC is Win7 Pro x86.
Steps taken on Win7 Pro x64 PC:
1) Installed http://firon.net/xda/usb_drivers_GalaxyS_x64.zip 64-bit drivers.
2) Plugged phone in, installed one driver fine, unplugged phone.
3) Enabled USB debugging and plugged phone in again. This is where I get the error. It just gets stuck on installing DCD Abstract Control Model (ACM). The other 3 drivers install just fine.
Steps take on Win7 Pro x86 PC:
1) Installed http://firon.net/xda/Samsung_Mobile_Driver_V1.3.800_For_SPH-d700_Epic_4G.zip 32-bit drivers.
Identical behavior, two different PCs. Anyone else experienced this?
