Results 1 to 25 of 26
- 09-26-2011, 12:01 PM
Thread Author #1
Universal car mount for use with TPU (or other) case?
It's been tough giving up a perfect fitting car mount like I've used in the past for my Evo 4G, iPhone 3G, and even the old Samsung Blackjack I and II. But I've decided I don't want my E4GT to end up as battered as my Evo 4G and so the only alternative is to use a case (I use a TPU case) and a universal car mount.
I would prefer to use a universal mount that is as minimalist/low-profile as possible (no gigantic arm/brackets on the sides or shelf on the bottom, etc.) but I haven't found anything that seems to be a nice fit yet. I checked out a few mounts on ebay that look pretty decent, but I'm not sure if they'll fit well, or at all. I can't post the links (my work computer blocks ebay) but they can be found by searching for:
"mountek car mount 4 htc evo shift 4g auto cd dash stand" (this one has an odd CD-tray mounting mechanism)
"car windscreen mount holder for samsung galaxy s2 i9100"
"black macally mcup universal cup holder phone car mount for cell phones" (this is the one I like the most but not sure if it would accomodate the girth of the E4GT and the seller doesn't seem to be accepting inquiries)
Any suggestions would be great, thanks! - 09-27-2011, 01:25 AM
Thread Author #2
- 09-27-2011, 05:11 AM #3
Re: Universal car mount for use with TPU (or other) case?
i have the Mountek and works great for me. I don't mind sacrificing the cd slot as i no longer use it. All my music is from pandora via Bluetooth streaming. It worked great on my Evo and now the Epic Touch.
When i went away on assignment, the mount came in handy as the phone was my GPS. Setup is easy and minimal. Can be easily removed from the rental vehicle.
The only issue i had is getting a phone with its side buttons not getting in the way of the clamps. When I did have the Photon, the clamps were pressing onto the button. In the case of the Epic Touch, it clears it. - 09-27-2011, 08:13 AM #4
I have to give props to the Mountek as well.
- 09-27-2011, 10:10 AM #5Sprint Smartphones: HTC Touch to HTC Diamond to Palm Pre to HTC EVO 4g (returned within 30 days) to Samsung Epic 4g to Epic 4g Touch to Galaxy Note 2.
- 09-27-2011, 06:33 PM #6
- 09-27-2011, 07:01 PM #7
Mounteks website has a picture of the unit that appears to have the unit mounted in a cassette player but the site doesn't say anything about that. It looks like the cd tray piece is removable allowing it to fit in cassette players also. The semi truck in drive only has a cassette.
- 09-27-2011, 07:07 PM #8
- 10-02-2011, 10:01 PM #9
- 10-03-2011, 02:56 AM #10
- 10-03-2011, 01:12 PM #11
- 10-04-2011, 07:07 AM #12
- 10-05-2011, 05:11 PM #13
- 10-05-2011, 10:30 PM #14
I have this Kensington mount and absolutely love it:
Amazon.com: Kensington K39217US Universal Windshield/Vent Car Mount for Smartphones, including iPhone 4S (Black): Cell Phones & Accessories - 10-06-2011, 02:11 AM
Thread Author #15
- 10-06-2011, 12:10 PM #16
- 10-06-2011, 12:13 PM #17
No, there's no pinching or distortion - it's almost as if it were made to hold the phone with the TPU case. I've also have a universal mount, but this one is MUCH easier to use with the E4GT + TPU.
I've found the stick on ones for a few bucks cheaper, but I wanted it fast, so I paid a little more for a stateside seller:
Of course there's also the friction mount version, vent mount version, cup holder version, bike handlebar version, etc.....
- 10-06-2011, 03:42 PM #18
I also bought the Sprint case and holster and it fits in the Nuvi 200 mount as well.
Sprint Smartphones: HTC Touch to HTC Diamond to Palm Pre to HTC EVO 4g (returned within 30 days) to Samsung Epic 4g to Epic 4g Touch to Galaxy Note 2. - 10-06-2011, 06:01 PM
Thread Author #19
Great, thanks. It looks slightly different than the Hong Kong one but better in that it doesn't stick out as much. Guess I'll see which one is better (I ordered the US one after ordering the HK one last night).
Btw, the McNally car mount that I linked in the first post does *not* fit the E4GT. It's way too small. - 10-07-2011, 01:42 PM #20
- 10-08-2011, 09:46 AM #21
I tried it on the dock for my Garmin Nuvi 260w and it fit like a glove, too. I have a feeling just about any dock for a 4.3" Nuvi will work.
Both my TPU case and my wife's purple case she bought at the Sprint Store fit well. I took it for a test drive down a gravel alley, no slippage at all. A pretty solid and cheap option. $8 bucks shipped from the US all over eBay. I'm buying another one for my wife's car.
Good looking out, Android Central. - 10-11-2011, 06:49 AM #22
Hey guys, Been going NUTS looking for a car mount for my E4GT! Does that Garmin holder turn so u can have it in Portrait and Landscape? Also any problems charging it at the same time? Just wanna know cuz it looks like that is the one Im going to go with!! I also have a TPU case and I seen u guys said it fits perfect with a TPU case so thats a major plus!!
- 10-11-2011, 11:19 AM #23
I think you're right. The ebay listing that I bought from shows the mount bracket as the same for models:
Originally Posted by WVUPharm2007
200, 200W, 250, 250W, 260, 260W, 270, 205, 205W, 255, 255W, 265T, 265WT, 275T
It's a ball joint, so you can rotate and angle it to whatever position you want. The charge port isn't blocked, so there's no reason you can't plug power in while it's in the mount. In fact, I bought another one (suction cup version), to use on my desk as a desktop stand!
Originally Posted by aaron130
- 10-11-2011, 08:23 PM #24
- 10-29-2011, 11:06 PM #25
These work perfectly. A must have car mount.
http://www.amazon.com/SoundGate-M2-e...idcentral00-20
Reply
